Old 25-01-2006, 09:12 PM   #1 (permalink)
Default BEST SECUTRITY SUITE....
Hi guys,
Which do u think is the greatest of all internet security and comp optimization software? Plz post ur reply..
pranavrahul is offline
Old 26-01-2006, 01:14 AM   #2 (permalink)
The Hardware Labs
mohit's Avatar
1. Ad Aware SE
2. Spy bot S&D
3. AVG Antivirus / Avast / Anti Vir PE
4. Zone Alarm
5. MS Antispyware
6. Ccleaner
a combination of the above all is the strongest FREE security suite .. and it will beat many (almost all) paid suites.
mohit is offline
Old 26-01-2006, 09:27 AM   #3 (permalink)
Distinguished Member
anandk's Avatar
zonealarm security suite.
tune-up utilities 2006.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 26-01-2006, 11:05 AM   #4 (permalink)
Extheist
aditya1987's Avatar
McAfee Internet Security is the best!!
Meowww......
aditya1987 is offline
Old 26-01-2006, 11:28 AM   #5 (permalink)
Wandering in time...
Ankur Gupta's Avatar
I'd certainly say AD AWARE SE and MS antispyware can remove any spyware and adware from ur computer!
Ankur Gupta is offline
Old 26-01-2006, 03:43 PM   #6 (permalink)
18 Till I Die............
I'd go for
1) Avast/AVG antivirus
2) Zonealarm Firewall
3) Spyware Blaster
4) Spybot S&D
5) Adaware SE
6) MS Antispyware(optional)
7) Any antispam tool (if you use POP mail.)
http://www.bash.org/?258908
mehulved is offline
Old 29-01-2006, 06:14 PM   #7 (permalink)
!FREEWARES!
Akshay's Avatar
Norton Antivirus 2006 & Zone Alarm v6.xxx n above wud be a deadly combo... MS antispyware is known to crash sys. I have tried spyware blaster, ms antivirus, avg, avast, etc. & I surely can say norton & zone alarm r d best
MBP 13.3";
PC: Core i-5 2400, Intel H67, GSkill 4GB DDR3, Sapphire 6850 Toxic, 1TB HDD, Samsung P2370
Akshay is offline
Old 29-01-2006, 07:46 PM   #8 (permalink)
But norton is a very big resource hogger. I find avast better for my needs alos it is free so no reason for piracy.
mehulved is offline
Old 29-01-2006, 09:14 PM   #9 (permalink)
If you are considering a stand-alone security suite then Zone Alarm is the best.I had been using it for many months now however I was not quite confident of its antivirus.So currently I am using Zone Alarm Pro and AVG Antivirus 7.1 Pro as the firewall and antivirus combination.
As far as comp optimization software goes Tune-Up utilities 2006 together with Ashampoo Winoptimizer should suffice.
Do I really need a signature to be unique?
allindrome is offline
Old 29-01-2006, 09:30 PM   #10 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
norton 2006 is not a resource hogger
norton 2005 was !!!
anyways,
i use
AVG 7.1
Zonealarm
Ad-Aware
Spybot
vijay_7287 is offline
Old 29-01-2006, 09:51 PM   #11 (permalink)
Netjunkie's Avatar
Norton Antivirus 2005 SE (from Google Pack, not the paid version)
ZoneAlarm Free Firewall
Spybot - Search & Destroy
Ad-Aware SE Personal
These do the job for me.
Netjunkie is offline
Old 30-01-2006, 09:09 AM   #12 (permalink)
Try Kaspersky and System Mechanic
There is a very fine line between genius and insanity. I have erased this line.
freezer is offline
Old 30-01-2006, 10:35 PM   #13 (permalink)
I have used Kaspersky anti hacker as well as anti virus. But they tend to stop my comp from accessing any pages after like 25 - 30 min without my permission. If i close them my comp works fine
Old 31-01-2006, 05:30 PM   #14 (permalink)
The pWnster
Vyasram's Avatar
norton internet sec 06 and sys works prem 06 + ms giant antispyware
Sigs suck
Vyasram is offline
Old 31-01-2006, 09:08 PM   #15 (permalink)
Norton 2006 uses rootkits. I wouldnt reccomend it at all. And Norton does not have the best detection rate.
AMD 64 3500+ Venice
DFI Lan Party Ultra-D
XFX 7900GT 256 MB Card
icecoolz is offline
Old 04-02-2006, 11:36 PM   #16 (permalink)
busyanuj's Avatar
one package with all the best of softwares doesn't actually work for most of the users.
try a combination of:
ZoneAlarm Pro as firewall.
Kaspersky as the AV.
MS Anti-spyware along with Ad-aware or Spybot as the anti-spyware.
Raxco PerfectDisk 7 as the disk defragmenting software.
it should work fine.
busyanuj is offline
Old 07-02-2006, 09:37 AM   #17 (permalink)
GaurishSharma.com
gary4gar's Avatar
A UPDATE:guys, zone alarms is spying on u
so dont use it
gary4gar is offline
Old 07-02-2006, 02:41 PM   #18 (permalink)
Default Reply
Similar Thread is running, y dont u all continue posting over there.
http://www.thinkdigit.com/forum/view...078&highlight=
Andyiz is offline
