| Forum |
#1 (permalink) |
hasta la vista baby |
#2 (permalink) |
You should have formatted it from FDISK and then installed xp( the installation cd is bootup disk as well).
What is happening now is that some files of the previos version are conflicting with the newer installation, resulting in that kinda change. I suggest you bootup with a floppy disk or the cd and format the drive followed by a simple windows installation. 8)
Dont ever involve in a dispute with a fool. The viewers might not be able to distinguish between the two
#3 (permalink) |
Hi,
if you dont wants to re-install and managed all the things again , and if your filesystem is NTFS compressed it , or run convert c: /fs:ntfs to convert existing file system to convert into ntfs Regards
With Regards Hemant S. Goswami MS SQL Server MVP http://hemantgirisgoswami.blogspot.com/ "Humans don't have Caliber to PASS TIME , Time it self Pass or Fail Humans"- Hemantgiri S. Goswami |
#5 (permalink) |
Hi,
the command i give will not format drive it will just convert the file system to NTFS . Regards
| Bookmarks |
| Thread Tools | |
| Display Modes | |
