| Forum |
#1 (permalink) |
What is this? please help and tell me some remedies. |
#3 (permalink) |
I have Norton and scanned my system a trojan was found and it automatically deleted the infected file.Onwards that scan whenever i start my computer I am getting thr error and too in desktop after it boots up and not while booting.
#4 (permalink) |
had da same problem few months ago.this was due to some search bar or something.i removed it and got da same messages u r havin.try running HijackThis.see da log file for strange or unknown entries.delete them.
if this is too complicated ask SWATKAT for help with da log file.he had helped me once with da same thing. |
#6 (permalink) |
ibm00*.exe is created by trojans Troj/Torpig-C and Troj/Torpig-J. Info at http://www.sophos.com/virusinfo/anal...ojtorpigc.html and http://www.sophos.com/virusinfo/anal...ojtorpigj.html provide details. You have specified that Norton found the trojans and deleted them. Check the log of the scan to confirm that these specific trojans have been removed...
If you have removed them, all that is left is for you to remove the entry from the startup list... Run msconfig and go to "startup" tab and uncheck the entry that specifies the file. Arun |
#9 (permalink) |
Distinguished Member
ya, its a trojan allright.
download and use the 'ewido anyi-malware suite' from www.ewido.net/en/ it shud help u. also check the solution here http://help.lockergnome.com/lofivers...hp/t42471.html
> www.TheWindowsClub.com < = www.WinVistaClub.com = Microsoft® MVP |
#10 (permalink) | |
My Blogs ______________________ http://laughlines.rediffblogs.com http://krrajesh.blogspot.com |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
