Old 21-01-2006, 12:18 PM   #1 (permalink)
Default Problem with IE
1>I installed a desktop shell replacement software so that my desktop looked like a mac pc.
2> few days later i installed Internet explorer 7 beta version.
3>then i got bored of my mac desktop and uninstalled the software. but it replaced the old(version 6) iexplore.exe.
4> this corrupted my IE. now its niether 6 nor 7.
5>i face a lot of problems now- there is no uninstallaton method for IE7.
and reinstalling IE7 doesn't help as it says it's already installed.
I would very much like to get back to IE6. Can anyone tell me how can i restore IE6 with out reinstalling windows...
Nikhil Prabhakar
Executive Trainee,
NTPC Ltd.
nikhmail is offline
Old 21-01-2006, 01:03 PM   #2 (permalink)
try going to add/remove programs and going to "add/remove windows components" and uncheck the "internet explorer" and click apply or watever and see if it uninstalls IE. if done... go there again and tick it and install it. wud ask for xp/2000 cd...
reply back if it worked.
/legolas
legolas is offline
Old 22-01-2006, 06:30 PM   #3 (permalink)
Default i had tried something similar
I had removed internet explorer from ad/remove windows components but interenet explorer was still there. but i didin't reinstall IE.
I'll try reinstalling ... thanks
Nikhil Prabhakar
Executive Trainee,
NTPC Ltd.
nikhmail is offline
Old 23-01-2006, 08:47 AM   #4 (permalink)
softhunterdevil's Avatar
TRY TO DELETE THE FOLDER OF INTERNET EXPLORER
REMOVE THE REGISTRY KEYS
RESTART
RE-INSTALL INTERNET EXPLORER 6.0/7.0
RESTART AND SEE IF THERE IS EVERYTHING OK
Hope this will help you!
softhunterdevil is offline
Old 23-01-2006, 12:53 PM   #5 (permalink)
rajesh's Avatar
Reinstalling should make things work fine again.
If not working, try repairing the IE 6 installation using ur Win CD.
My Blogs
______________________
http://laughlines.rediffblogs.com
http://krrajesh.blogspot.com
rajesh is offline
