Old 21-01-2006, 11:54 AM   #1 (permalink)
Default Installation starts when opening some programmes.
Dear Brothers.
OS: Windows XP SP2
CPU:AMD Athlon 2000 XP
Motherboard: Gigabyte 7VM333M-RZ(-C)
RAM:512MB 333Mhz
when i open programmes like Registry Mechanic or Microsoft Encarta some other programme's installation starts.
Help me to solve my problem.
Thank you in advance.
sm_ashiq is offline
Old 21-01-2006, 12:22 PM   #2 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
i think got to do with a faulty installation
maybe u have just copied the installation folder folder from a friend rather tha installing it frm a setup file
vijay_7287 is offline
Old 22-01-2006, 12:12 PM   #3 (permalink)
If I am not wrong, what is happening is that you are getting a "Preparing to install..." progress bar or "Configuring..." progress bar. Log in as administrator and run the programs (Registry Mechanic or Microsoft Encarta). When the progress bars appear, let it run completely. Then, restart the system and try to run the programs now... Hopefully, the problem would be gone. If not, run a complete install of the program for which you are getting the progress bar.
Arun
sakumar79 is offline
Old 22-01-2006, 12:48 PM   #4 (permalink)
Default Some Instalation starts when i open some programmes
Dear Friends,
OS: Windows XP SP2
MOBO: Gibabyte 7VM333M-RZ(-C)
RAM:256MB 333Mhz
CPU: AMD AthlonXP 2000+
when i open some programmes some software installation starts. Please help me.
sm_ashiq is offline
Old 22-01-2006, 02:30 PM   #5 (permalink)
Laptoping
Sourabh's Avatar
Share some more info the programs, what installations? IF possible post some pics of the software installation which starts to troubleshoot the problem
Sourabh is offline
Old 22-01-2006, 02:58 PM   #6 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Seems like he is talking about MS Office components!
I hv also faced the same thing!
It happenes when u didnt install the whole components and when u open the application, it starts installing the required components automatically!!!
http://www.AskVG.com/
Vishal Gupta is offline
Old 22-01-2006, 05:57 PM   #7 (permalink)
Sorry Friend,
when i open Registy Mechanic, LGDownload programme, which i earlier installed on my computer, starts to install and it says CD not found in the drive please insert.
i found same problem while opening some other but i didn't remember which programme.
sm_ashiq is offline
Old 22-01-2006, 06:06 PM   #8 (permalink)
Microsoft MVP
Ok Ok.....
Hold down man. We understood ur problem
Why r u posting the same thing so many times?
First tell me, did u install those s/w from CD?
U can do one thing, make dump of the setup on ur HDD and again open the s/w in which u r facing the problem and when it asks for CD, give it the location of the dump and it'll reinstall the s/w with the required files.
And I think ur problem will be solved!
Old 22-01-2006, 06:11 PM   #9 (permalink)
Learner
Kniwor's Avatar
U might have cached some files of those programs earlier and the deleted them, now it tries to install from those files and could not find them.
see to it that any process related to those program does not start at startup
Kniwor is offline
Old 22-01-2006, 07:03 PM   #10 (permalink)
Originally Posted by Vishal Gupta
Ok Ok.....
Sorry my dear friend,
I didn't posted it purposely. it was an error. my computer didn't respond so i clicked submit button thrice.
I didn't install LGDownload s/w from CD. I downloaded that programme fron internet and installed from Harddisk.
I installed Registry Mechanic one month back and LGDownload two weeks back and LGDownload is working fine even now.
sm_ashiq is offline
Old 22-01-2006, 08:17 PM   #11 (permalink)
swatkat's Avatar
Hi,
Use Microsfot Windows Installer Cleanup Utility. Here's more info.
http://swatrant.blogspot.com/
swatkat is offline
Old 22-01-2006, 08:38 PM   #12 (permalink)
Thank You All for you help
sm_ashiq is offline
Old 23-01-2006, 11:01 AM   #13 (permalink)
parthbarot's Avatar
May be its a virus...as i faced it just before 4 days...so please update ur antivirus first and scans all ur HDD ok? try to fix if u find it...Bcs it eats ur exex...may be...
regards,
www.techlads.com
Paarth.
parthbarot is offline
