Old 21-01-2006, 03:50 AM   #1 (permalink)
Default plzzz help ..referenced memory error
im getting these type of errors regularly while opening a website and also sometimes playing the game swat.. can someone plzzz tell me the reason and solution.....
the instruction at "0xf2bcc49d" referenced memory at "0xf2bcc49d". The memory could not be "read", click on OK to terminate[/i]
sanprince is offline
Old 21-01-2006, 10:39 AM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
r u using windows 2000?? make sure u have the latest service pack...
i dont know why but few my frnds who use to run windows 2000 gets this error often... they just upgraded to windows XP & now their system runs fine...
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 21-01-2006, 11:38 AM   #3 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
i get those errors in XP alsoo
why?
vijay_7287 is offline
Old 22-01-2006, 12:36 PM   #4 (permalink)
Could be due to problem in RAM. First, open the system, take out the RAM module(s) and gently clean them. Then, put it/them back and make sure that the seating is proper. Now, restart your system and see if problem reappears... If it does, download MemTest and run it to see if there is any problem with the RAM module...
It is also possible to have been caused by device drivers for which you can check out http://support.microsoft.com/kb/q244617/
If this problem is limited to only IE and SWAT, it could be program bugs also... Look at Event viewer in Control Panel->Admin tools and post a list of various errors over the past few days... could be useful...
Finally, also inform what checks you have conducted for spyware, virus, adware, trojans and what security software (antivirus, firewall, anti-spware, etc) you are using...
Arun
sakumar79 is offline
