Old 21-10-2004, 07:32 AM   #1 (permalink)
Default Gaming & media player problems
Hi Everybody
I have got the following problems :-
1. When I try to play Crazy Spheres Game, I receive message "Not enough memory or disk space (314572800 MB required)."
2. For Evil Games Demo Game, I receive message "A required .DLL file, D3D9.DLL , was not found".
3.When I try to play some VCD's, following message comes:-
"MM SYSTEM281. This file could not be played. Check the filename or install a driver that supports this type of file."
My PC particulars : Zenith Intel Celeron 2.2 GHz / 128 DDR Via M/B with Lan / 40 GB HDD / Audio on board integrated Graphics / 52xCD Drive.
I am new to Computer, KINDLY HELP
rameshld2000 is offline
Old 21-10-2004, 09:56 AM   #2 (permalink)
ice
Win Xp or WIn 9x?
U prolly need to Reinstal Direct X 9.0c.
Umm u have just 128mb ram, so that expains ur gaming problem..
Edit : Wait d3d is opengl's counter part, so that means eaither u need gfx drivers for ur onboard card or directx9.0c
ice
ice is offline
Old 21-10-2004, 03:00 PM   #3 (permalink)
Windows 98 , kindly suggest how to Reinstall 9.0 & gfx drivers.
Where there is a WILL there is a WAY !
Old 21-10-2004, 03:39 PM   #4 (permalink)
Davislav Ivanuiz!!!
Kl@w-24's Avatar
Just run dxsetup again. That ought to reinstall Direct-X. As for th gfx card drivers, u need to remove all traces of th older drivers first, from 'Add/Remove Programs' in 'Control Panel'. After this, re-run ur gfx drivers setup file.
I was here when the forum's swear filter kept bleeping out the word 'FUNK'. :crazy::censored::eeksign:
www.abhi247.com | The Photohblog A Little Lunacy! [v3]
Flickr!
Kl@w-24 is offline
Old 23-10-2004, 08:36 AM   #5 (permalink)
Hey !
Running dxsetup again & re-running gfx drivers has not solved my problem. Is it possible to patch .dll files as it is required for Evil Games Demo. Kindly suggest.
Old 23-10-2004, 08:54 AM   #6 (permalink)
ice
hmm
here is the dll
http://www.dll-files.com/dllindex/dll-files.shtml?d3d9
Which graphic card do u have? did u get the latest drivers for it? from the net?
ice
ice is offline
Old 23-10-2004, 09:28 AM   #7 (permalink)
Audio on-board integrated graphics. latest drivers : don't know.
Old 23-10-2004, 10:29 AM   #8 (permalink)
Bewitched!
xenkatesh's Avatar
try googling and find it inthe net or at the manufactures website dude!
Keep your friends close and enemy CLOSER!!!
Ragnarok Online: One World, One Million Possibilities.. :)
xenkatesh is offline
