Old 04-01-2006, 03:42 PM   #1 (permalink)
Default my pc checks for floopy for every 5 minutes
my pc checks for floopy for every 5 minutes and its quiet irritating
there is no virus i did a check in the safe mode
viruses is offline
Old 04-01-2006, 07:52 PM   #2 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
it did happen to me
just look for the files tht are gettin on to the floppy each time u use ur drive
and do a search(includin the hidden files) for them on the home drive on the HDD
and delete them
this should solve it
vijay_7287 is offline
Old 05-01-2006, 01:09 AM   #3 (permalink)
go here Similar problem has been discussed and tehre are many alternative suggestions given... hope u get it solved atleast with 1. thou u dint mention your OS! coz i dont think xp sp2 wud giv this prblem? i hav never experienced this problem. may be i dont hav antivirus scanner and so! coz in the link i gave, one of them attributed the prb to nortion internet security and antivirus and hav told how to disable floppy scan by symantec. go thro it. GL.
/legolas
legolas is offline
