Old 20-10-2004, 10:09 AM   #1 (permalink)
Default unique problem in Win98
I wanted a play dos mode game so I in Windows directory I clicked on the icon stating XMS support for MS-DOS Games.
Now When I start my Pc it always starts in Dos mode and even if I type EXIT it again starts in Dos mode.
I installed Win98 again but the problem remains as it is.
please help
harshagarwal is offline
Old 20-10-2004, 12:41 PM   #2 (permalink)
Edit the file msdos.sys in the root directory (it's hidden) and change the BootTOGUI = 0 option as BootTOGUI = 1.
I don't remember the exact word 'cause i don't use win98 now, but there are very few lines in the file so you can easily find and edit. You will have to change the attributes of the files for editing it.
jnpandya is offline
Old 20-10-2004, 01:55 PM   #3 (permalink)
i cannot get the GUI how do I edit the file and change its attributes in the dos mode
Old 20-10-2004, 03:25 PM   #4 (permalink)
You can boot to windows by typing win at the dos prompt.
For permant solution , In dos mode , on C:
Type attrib -r -h -s msdos.sys
When attributes are set
type edit msdos.sys
My msdos.sys looks somthing like this
[Paths]
WinDir=C:\WINDOWS
WinBootDir=C:\WINDOWS
HostWinBootDrv=C
[Options]
BootMulti=1
BootGUI=1
DoubleBuffer=1
AutoScan=1
WinVer=4.10.2222
and so on
change bootGUI = 1
BlAsTeR is offline
Old 20-10-2004, 06:08 PM   #5 (permalink)
I think BlAsTeR has very clearly answered your question.
jnpandya is offline
Old 21-10-2004, 07:58 AM   #6 (permalink)
I did by booting my system in safe mode.
checked the msdos.sys file was alright but something scrap was there in config.sys and autoexec file so i cleaned it up and now my Pc runs fine.
thanks for telling me the use of msdos.sys file.
- by chris
