hi,
i hav a few questions
1) can i adjust the brightness of a
non-DVD-movie in POWERDVD?? if so, where is the option? i cudnt see any
2) in WinDVD, if at all i hav a ful registered copy, wil the surround effect plugins and otehr effects work only for DVD movies again? cant i set an equalizer effect for say an xvid movie?
3) i was planning to edit a movie to some extent.. to play with.. i tried soundforge but it wudnt open the .avi file even (even though it has the extension under the compatible file type open combo box). i got a suggestion before from a post to try sony vegas... but it wudnt play the movie either... i need to strip the audio from the movie(xvid), convert to AC3, if possible to a 5.1 from 2 channel and then add to the movie back... how can we do this using vegas? and any other software available for doing this?
4) in windows media player, when in full screen mode, we move the mouse and a bugging options mode comes in both top and bottom (mp 10)... is there anyways it doesnt come even if i move the mouse? incase i want to adjust any.. i wud go to small screen adjust and come back. coz in VLC the only other player i prefer doesnt hav subtitles psotioned in the "black portion" of the screen... i ahv to go for wmp. i dont use powerdvd now coz of the problem already mentioned above, brightness.
5) is there any software to get full information reg. a video? say the format if its NTSC or PAL, encoding as to 1 pass or 2 pass, xvid or divx, frame rate, audo codec & rate etc.. all possible information?
i am a little ignorant abt these.. so pls help me out!
/legolas
