Old 24-12-2005, 02:41 AM   #1 (permalink)
Default AZUREUS PROBLEM
although seeds are available, 99% of them are in swarn.my firewall is OFF and antivirus firewall is also OFF still the problem occurs.PLZ help
god_of_frauds is offline
Old 25-12-2005, 10:07 PM   #2 (permalink)
could be a nat problem
look at the status bar if theres a red dot there
thats y u cant connect directly to the seeds
still u SHOULD be able to connect to some seed at some point ...
No Mercy, No Limits.
theraven is offline
Old 26-12-2005, 12:36 AM   #3 (permalink)
AMD user for 9 yrs!!
rollcage's Avatar
theraven
I also would like to the solution to the guyz problem
Since, I can connect through BitComet but not through the Bittornado & Azureus
I have MTNl triband 256kbps
rollcage is offline
Old 26-12-2005, 01:07 AM   #4 (permalink)
the problem is with your port settings and not with your firewall or anti-virus
viruses is offline
Old 26-12-2005, 09:24 AM   #5 (permalink)
http://www.thinkdigit.com/forum/viewtopic.php?t=33319
this will help u for bsnl/mtnl configuration
Shwetanshu Srivastava
shwetanshu is offline
- by chris
