Old 21-12-2005, 07:39 AM   #1 (permalink)
Gracias Senor
dreams's Avatar
Default Explorer Problem !!!
Hello all..
2 days bac i was playin Hulk the game and in the middle i got stuck.. i was forced to do a restart.. after restarting my explorer is gone.. and also my sys hangs a lot and culdnt c any windows correctly.. so wat i did was reinstalled my Video Drivers.. but in vain.. then got an idea and unloaded Windowblinds 5.. wat a surprise all workd fine.. so uninstalle Windowblinds permanently.. but the prob is whenevr i restart my PC i culdnt c my explorer.. it takes abt 5-10 min for it to appear..
i even copied the explorer.exe frm Windows XP CD and it seems not 2 work.. wat can i do now.. help pls.. TIA
iPT 2G(S) - 8GB - JBn
iPhone 3GS 16GB - JBn
MAC OSx86 on P4 2.4Ghz
HTC Touch - Elfin - P3452 - WM 6.5
- Dont Dre@m... Juz Chase it -
dreams is offline
Old 21-12-2005, 09:45 AM   #2 (permalink)
Indian by heart
planetcall's Avatar
put the XP CD in and run the setup. Choose the option upgrade.
प्रासादशिखरेऽपि सन्न काको गरुडायते ॥
No matter how high a fool may rise, he remains a fool -RigVeda
planetcall is offline
Old 22-12-2005, 07:23 AM   #3 (permalink)
Gracias Senor
dreams's Avatar
will i hv 2 reinstall all the appz or it juz replaces the windows files ??? Also whr can i find the Upgrade option in XP. I think i can c Fresh Install, Repair. How 2 do it ??
TIA
dreams is offline
Old 22-12-2005, 09:25 AM   #4 (permalink)
did u try a system restore? to a point before u installed windowsblind?
/legolas
legolas is offline
Old 22-12-2005, 04:20 PM   #5 (permalink)
d
yep...i think u shld use "repair" not upgrade only as a last resort...try system restore n see if it works...mostly it shld!
The torquemaster rules.
d is offline
Old 22-12-2005, 06:08 PM   #6 (permalink)
WB5...
Was u using a crack...
Use system restore or at last do a repair..
Computer.
Whats that.
Is it some kind of frog.. turr turr turrr...
con_tester is offline
Old 24-12-2005, 07:42 AM   #7 (permalink)
Gracias Senor
dreams's Avatar
I do used the repair option frm XP CD.. when i first experiencd this prob i loaded my XP Cd and did a repair.. and i searched for the explorer files in system32.. astonishingly i culdnt find any.. so i copied explorer.exe and explorer.scf frm the cd and pasted in the system32 folder.. but also the same prob persists..
And i too did the sys restore.. but no restore point is saved or shown.. but nw i hv find a solution.. i.e., i am not restartin my PC nowadays.. juz hibernatin.. any other fixes..
dreams is offline
- by chris
