Old 21-12-2005, 07:27 AM   #1 (permalink)
Gracias Senor
dreams's Avatar
Default Nokia PC Suite Problem !!!!
Hello all..
I hv a Compaq Presario 2100 Laptop and tried to install Nokia PC Suite in it.. I tried all versions frm the old to the latest 6.6..
I am gettin a error durin installation..
Error No. 1607 - Cannot install InstallShield Runtime Error.
I get this error in the starting itself.. So unable to install..
I think the problem is with Windows Installer cos the Installer stops and produces the error when it is configuring Windows Installer.. it hangs for a while in this process and then produces the error..
PC Config..
MS Win XP Pro 2002 with SP2
320MB RAM
Pls help !!
TIA
iPT 2G(S) - 8GB - JBn
iPhone 3GS 16GB - JBn
MAC OSx86 on P4 2.4Ghz
HTC Touch - Elfin - P3452 - WM 6.5
- Dont Dre@m... Juz Chase it -
dreams is offline
Old 23-12-2005, 02:31 PM   #2 (permalink)
Here is a link which i hope will help you.
Link
Massacre is offline
Old 23-12-2005, 04:54 PM   #3 (permalink)
Gracias Senor
dreams's Avatar
thnx m8.. seems 2 b useful.. wil try those fixes and revert bac.. thnx a lot..
dreams is offline
Old 24-12-2005, 12:21 PM   #4 (permalink)
::cyborg::'s Avatar
update ur installer
::cyborg:: is offline
Old 25-12-2005, 08:23 AM   #5 (permalink)
Gracias Senor
dreams's Avatar
Originally Posted by ::cyborg::
update ur installer
I hv Enabled Automatic Updates and Installer had been Updated automatically.
dreams is offline
Old 17-07-2007, 10:10 AM   #6 (permalink)
Boom Boom Boom
cooldudie3's Avatar
Default Re: Nokia PC Suite Problem !!!!
that pretty funny have u tried wat the other guy said that had the link?
I'm back! Gimme a hugggggg... :D
cooldudie3 is offline
- by chris
