Old 19-12-2005, 12:16 AM   #1 (permalink)
Default WindowBlinds-Help!!
I just got the windowblind regtration no. I had the tryout version installed... earlier..
What do i do now to get it upgraded to full version to use all the features!!!
http://ravifriendz.co.nr
Ravi.
http://ravishchandra.blogspot.com/
Ravi+ish is offline
Old 19-12-2005, 12:33 AM   #2 (permalink)
dIgItaL_BrAt's Avatar
U have to download the registered version from Stardock's site.That verion gives u the option of entering ur serial number.
dIgItaL_BrAt is offline
Old 19-12-2005, 07:17 AM   #3 (permalink)
vignesh's Avatar
Yes you have to download the reg version...But how did you get the register number
vignesh is offline
Old 19-12-2005, 07:32 AM   #4 (permalink)
Hey Ravi...May I ask u where u got the registration number from? Did u buy the WB 5 package??
If u didnt buy the package & got the registration number frm elsewhere (ssshhhh)...cud u plz PM the link to me??
Peace
h_kunte is offline
Old 19-12-2005, 06:17 PM   #5 (permalink)
Distinguished Member
anandk's Avatar
Peace
check ur pm/mail.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 19-12-2005, 06:25 PM   #6 (permalink)
Hey anandk...
Thanx a million for sending me the link, but as far as I know, that too is a day-limited trial s/w....what say??
h_kunte is offline
Old 21-12-2005, 07:11 AM   #7 (permalink)
Gracias Senor
dreams's Avatar
I hv the full version of WB 5 and it rocks.. but unfortunately i hv some problems with it and so removd it.. dunno if any others exp the same prob..
dreams is offline
Old 21-12-2005, 09:50 AM   #8 (permalink)
Indian by heart
planetcall's Avatar
All users using WB5 will be !!!!ed up. They seem to be detecting the pirated editions and then wrecking havoc. Everything became black and the system was darn slow. Lol I removed WB5 and xp works fine. I think KDE is more sexy and blinds the user instantly and whatsmore........it comes free.
प्रासादशिखरेऽपि सन्न काको गरुडायते ॥
No matter how high a fool may rise, he remains a fool -RigVeda
planetcall is offline
Old 21-12-2005, 12:25 PM   #9 (permalink)
anandk's Avatar
Hey anandk...
nope, its stl working !
Microsoft® MVP
anandk is offline
Old 22-12-2005, 12:26 AM   #10 (permalink)
What exactly were the probs.! Plz share here... is there some display with the grphics? I think it'd help if i know the problems that i MAY have!!!
AND, as all of you asked!! i must tell you had just downloaded the version4.1 of WB!!
Ravi.
Ravi+ish is offline
Old 22-12-2005, 01:29 AM   #11 (permalink)
gxsaurav
Posts: n/a
the UI is not skinned & the whole system is slow as hell, however a new crack is out now too, with this timebomb fixed
Old 22-12-2005, 07:20 AM   #12 (permalink)
Gracias Senor
dreams's Avatar
As planetcall told i too exp a black out of all the areas tht r skinned usin WB5. i.e., the task bar, title bar tht r skinned usin WB 5 doesnt appear.. instead it bcums black and also the sys hangs a lot.. i didnt exp any for the first few weeks..
it all hap when i was playin a game HULK.. it got stuck when i was abt 2 save and stupidly i restarted the machine.. which must hv corrupted the explorer and WB 5. So now i hv uninstalled WB 5. Must install the older version.
@gxsaurav
Can u juz PM me the crack link tht has theis flaw fixed.. thnx
iPT 2G(S) - 8GB - JBn
iPhone 3GS 16GB - JBn
MAC OSx86 on P4 2.4Ghz
HTC Touch - Elfin - P3452 - WM 6.5
- Dont Dre@m... Juz Chase it -
dreams is offline
Old 22-12-2005, 09:45 AM   #13 (permalink)
anandk's Avatar
hey, i take back my earlier post.
what dreams says, just hapnd to me too.
all blackening out !
must find a way...
Microsoft® MVP
anandk is offline
Old 22-12-2005, 01:10 PM   #14 (permalink)
must find a way...
Thats a time bomb in crack....of WB5..
Everyone who using that type of crack cant use WB5 after 18 December...
To use just set ur pc date to anytime before 18 december.....
or pm me for further details..
Computer.
Whats that.
Is it some kind of frog.. turr turr turrr...
con_tester is offline
Old 23-12-2005, 12:48 AM   #15 (permalink)
@gxsaurav
yeah... that vista theme is working fine in older installations!!!
Ravi.
Ravi+ish is offline
Old 23-12-2005, 10:35 PM   #16 (permalink)
MenTaLLyMenTaL's Avatar
Yes WB 5 has serious problem with it. I downloaded a full version of it thru torrent and after restarting after installing it, it slowed the pc so much that i couldnt even reach the Shutdown menu from Ctrl+Alt+del in 10 mins so had to press Reset btn. But earliew versions work fine.
Dont be reluctant to do MenTaL work.
MenTaLLyMenTaL is offline
Old 23-12-2005, 11:20 PM   #17 (permalink)
But don't you people think there must be a good copy of WB5 on the net thru ANYWHERE?
Well, i guess most of the probs are coming from the downloads from torrents and others like ... has anyone got a hand on the copy that's working fine from all directions???
Ravi.
Ravi+ish is offline
Old 24-12-2005, 12:44 PM   #18 (permalink)
Havent u all noticed my post...
WB5 Cracked version has a time bomb...
It will screw ur computer..
Do not use crack....
Computer.
Whats that.
Old 24-12-2005, 05:13 PM   #19 (permalink)
But later, i uninstalled WB5 (with crack applied). Then reinstalled it cleanly without the crack. But yet had the same problem. And i dont think that the crack will still remain from the time i applied it b4, there's no suspicious process of it or anything like that.
Old 24-12-2005, 08:01 PM   #20 (permalink)
If u uninstall WB5 Crack remain there.
U neeed to manually remove the WB5 folder to Delete crack files.
Its on Stardocks forum...
Computer.
Whats that.
Old 25-12-2005, 01:53 AM   #21 (permalink)
i am using the new cracked version and its giving me no probs till now.....
sahil_blues is offline
Old 25-12-2005, 04:30 PM   #22 (permalink)
I asked if there IS a copy of WB5 which has No problems... no matter if it's cracked or not!!!
Ravi.
Ravi+ish is offline
- by chris
