Old 16-12-2005, 09:43 PM   #1 (permalink)
Default asp with apache
can i use asp on apache? and if i use iis on my pc, how can i stop others from accessing the same from outside?
tech_lover is offline
Old 20-12-2005, 12:08 PM   #2 (permalink)
#/bin/sh's Avatar
Yes, you can,
Sun Java System Active Server Pages
http://www.sun.com/software/chilisoft/index.xml
^^ here
\"99 little bugs in the code, 99 bugs in the code, fix one bug, compile it again, 148 little bugs in the code. 148 little bugs in the code....\"
#/bin/sh is offline
Old 20-12-2005, 01:12 PM   #3 (permalink)
alib_i's Avatar
The site says ..
.Q:
Do you support desktop versions of Microsoft Windows (e.g., Microsoft Windows 95, Windows 98, Windows Millenium Edition (ME), Windows XP Home, or Windows XP Professional)?
A:
No. Java System Active Server Pages (formerly Sun ONE Active Server Pages) is designed for server software, not desktop operating systems.
Have you used it on desktop ??
btw, tech_lover ..
you might also take a look at these sites
http://www.apache-asp.org/
http://freshmeat.net/projects/apacheasp/
alibi
-Metallica
alib_i is offline
Old 27-12-2005, 05:44 PM   #4 (permalink)
Thanks for the links and replies. Can you tell me about the second part of the question? if i use IIS bundled with XP on my pc, how can i stop others from accessing the same from outside?
Old 27-12-2005, 06:13 PM   #5 (permalink)
alib_i's Avatar
outside = not your computer
or
outside = outside your private lan.
if 2nd option .. then it's automatically done. IntraLAN IPs cannot be accessed from outside LAN.
(ex. typing http://10.109.7.7 in browser wouldnt direct you to my intraLAN website running on my computer)
for 1st option ..
In IIS 5.0 bring up the Internet Security Manager, go to Properties on the Web server, then to Directory Security, then to IP Address and Domain Name Restrictions. Determine for each IP address or address range specified (through clicking on the Add option) whether to allow or deny access to the Web server.
(Source)
http://support.microsoft.com/kb/324066/EN-US/
alibi
-Metallica
alib_i is offline
Old 27-12-2005, 09:48 PM   #6 (permalink)
Thanks that solves my problem. With WIndows stuff I am alwats wary of security
Old 28-12-2005, 01:44 AM   #7 (permalink)
alib_i's Avatar
You're welcome !
alibi
-Metallica
alib_i is offline
- by chris
