Old 15-12-2005, 10:13 AM   #1 (permalink)
Make Way the LORD is Here
ssk_the_gr8's Avatar
Default scheduled task problem
how can i make a scheduled task for shutting a program at a particular time?
ssk_the_gr8 is online now
Old 15-12-2005, 10:42 AM   #2 (permalink)
ramprasad's Avatar
I dont think there is a direct way to do it until, there is a command whcih can be called from command line to close it....
One round about way is to use a Macro recorder and schedule the run for the macro using the Task Scheduler
ramprasad is online now
Old 15-12-2005, 01:17 PM   #3 (permalink)
hey dude i know nothin about macros
