Old 12-12-2005, 08:48 PM   #1 (permalink)
thetopcyborg's Avatar
Default Task Manager not running
Can anyone help me with this.
I was affected by two viruses recently: Bakdoor.IRC.Aladinz.R and W32.Alcra.B. They were both removed by Norton Internet Security 2006. But they corrupted my Task Manager. Now whenever I try to access the Task Manager, a message comes that 'Task Manager has been disabled by your administrator'. i have administrative privileges. I even tried this registry tweak which i found from a website but it isn't working:
[Start] [Run] [Regedit]Registry Key: HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre ntVersion\Policies\SystemModify/Create the Value Data Type(s) and Value Name(s) as detailed below.Data Type: DWORD Value // Value Name: DisableTaskMgr Setting for Value Data: [0 = Enabled (Default) / 1 = Disabled]Exit Registry and Reboot.
Please help me as i don't want to start working with a new account as most of my software is account-dependent.
thetopcyborg is offline
Old 12-12-2005, 09:11 PM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
* Click Start
* Click Run
* Enter gpedit.msc in the Open box and click OK
* In the Group Policy settings window
o Select User Configuration
o Select Administrative Templates
o Select System
o Select Ctrl+Alt+Delete options
o Select Remove Task Manager
o Double-click the Remove Task Manager option
Disable it
Source = http://www.windowsnetworking.com/kba...XPHomePro.html
Or try this small utility
http://www.dougknox.com/xp/utils/xp_taskmgrenab.htm
Recommended for ur system :
Go here and follow the removal instuctions for registry entries of the trojan/virii...
http://securityresponse.symantec.com...aladinz.r.html
http://securityresponse.symantec.com...2.alcra.b.html
QwertyManiac is offline
Old 13-12-2005, 04:56 PM   #3 (permalink)
Thanks manIt worked.
