Old 09-12-2005, 06:56 PM   #1 (permalink)
Default pls help me my win xp not shutting down
i get this error when i shut down pls pls help me
NagpurDaMunda is offline
Old 09-12-2005, 07:03 PM   #2 (permalink)
dIgItaL_BrAt's Avatar
where's the error??
dIgItaL_BrAt is offline
Old 09-12-2005, 07:54 PM   #3 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
Hmmm ... no error ...no answer
vijay_7287 is offline
Old 10-12-2005, 02:46 AM   #4 (permalink)
yrana2002's Avatar
Most probably, your shutdown has been disabled by somebody, it may have happened by yourself, someone who has administrator's rights only. A tool of the name Shutdown event tracker may have been enabled by somebody, which allows only the administrator to shutdown the pc. If it is enabled, you can do the following:
1.Open Group Policy.
2.Navigate to the Display Shutdown Event Tracker policy, and double-click it
Local Computer Policy/Computer Configuration/Administrative Templates/System
3.On the Setting tab, click Not Configured, Enabled, or Disabled.
4.Click Apply, and then click OK
Dont ever involve in a dispute with a fool. The viewers might not be able to distinguish between the two
yrana2002 is offline
Old 10-12-2005, 06:51 AM   #5 (permalink)
Alternative method to that suggested by yrana is to go to regedit, look for the key HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre ntVersion\Policies\Explorer and delete "NoClose"
Arun
sakumar79 is offline
Old 10-12-2005, 12:53 PM   #6 (permalink)
yrana2002's Avatar
Arun
I dont think so that will be possible since editing the registry requires administrator privileges.
Old 10-12-2005, 01:51 PM   #7 (permalink)
Editing the registry does not necessarily require admin priveledges... Anyone can edit HKEY_CURRENT_USER part of registry as it will affect that user only.
Arun
Old 11-12-2005, 01:09 PM   #8 (permalink)
Default Thank u all of u guyz
thankz thankz a lot ..................sakumar79 aka arun ur suggestion solved my problem ...thank u very much ...............10x again..............i edited my registry i mean deleted noclose .......n now my computer is getting shut off..................10x guyz
