He nishant if you are facing the same problem with azureus then it simply means that either the torrent you are trying to downloaded is not being seeded fast enough or has less number of seeders and maybe due to misconfigurations. BitComet has some speed problems which you can rectify by visiting their forum. Try to look in the settings and enable port forwarding/NAT etc. You will find a lot of articles to improve your torrent download speed using particular client of your choice on net.
The link by yrana is also very helpful
प्रासादशिखरेऽपि सन्न काको गरुडायते ॥
No matter how high a fool may rise, he remains a fool -RigVeda
