Results 1 to 4 of 4
Thread: Dialing Problem
  1. #1
    Dec 2005
    Default Dialing Problem
    By clicking dial on dial up connection, PC restarts without any warning. WinXP SP1. After clearing offline contents, problems is cured but same thing takes place after 2-3 reboots.
  2. #2
    Rebooting Choto Cheeta's Avatar
    Aug 2004
    hay... 1st post... so wellcome to the forum....
    hmm... may be a virus... so.. have u scaned the system with any GOOD avs like NAV or KAV??
    2nd thing... but confusing... as u said that "clearing offline contents" templly solves ur problem...
    as if that wouldnt happend... i would have written that may be a problem either with system power supply or with the MOBO....
    so 1st thing 1st... make sure u have scaned the system with good antivirus... & u have the latest driver for ur modem... considering loading the SP2... & if internel modem then try to switch the PCI slot... or if Serial modem then try to switch the port...
    rebooting
    ChotoCheeta.com
  3. #3
    Right Off the Assembly Line chatterjeesayan's Avatar
    Apr 2005
    I think,you're affected by blaster or sasser worm,pls download the fix from symantec's website and run it on your computer.
    NBisable system restore before running the fix.
  4. #4
    Live The Dream! agnels's Avatar
    Nov 2005
    Goa
    What are you waiting for. Do you think MICROSOFT give SP and updates just like that. Go and update your computer with SP2 and all the latest updates. Otherwise it will be hell while surfing the net. Don't take chances. I have already paid the price for not installing SP2 on one of my PC's. Also do a virus scan and spware scan. It's better you delete the connection and make a new one.
  1. dialing bsnl bb from 2 pcs
    By vicky_l7 in forum Broadband and DTH
    Last Post: 03-09-2009, 10:35 AM
  2. [Modem Problem] No dialing.. Please help..
    By //siddhartha// in forum Networking
    Last Post: 30-12-2006, 02:23 PM
  3. dialing through pc
    By Terahertz in forum Mobiles and Tablets
    Last Post: 19-01-2006, 11:19 AM
  4. dialing using sify
    By mohnishghodekar in forum QnA (read only)
    Last Post: 13-12-2005, 05:56 AM
  5. computer(win xp) starts dialing automatically
    By vikas_r_s in forum Software Q&A
    Last Post: 29-01-2005, 07:10 AM
