Old 04-12-2005, 12:59 AM   #1 (permalink)
Default problem with yahoo msgr
i have yahoo msgr 7 installed on my system. the problem is of late i am not able to get any offline messages. my brother n i share the same system n the same messenger. he gets offline messages n not me. also i am not able to folllow up un the links in yahoo messenger i.e. if some 1 sends me a link on clicking on it a new window does not open up..ne solutions techies..???
coolsid_59 is offline
Old 04-12-2005, 08:17 AM   #2 (permalink)
Try reinstalling it.
Any use of the collective descriptions and shared knowledge from any of my posts are at the sole discretion of the reader.I am not responsible for what you do with it.
rajas700 is offline
Old 04-12-2005, 08:58 PM   #3 (permalink)
Gracias Senor
dreams's Avatar
try the new version.. yahoo messenger with voice.. its gud and no errors..
dreams is offline
Old 04-12-2005, 11:28 PM   #4 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
It happenes when u use more than one web browser.
Do one thing!
Open IE and goto: Tools -> Internet Options and then goto Programs tab and click on "Reset Web Settings button" and make sure that "IE should check wether its default browser" checkbox is checked
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 05-12-2005, 04:03 PM   #5 (permalink)
[/quote]
no use man. i'm using the latest yahoo msgr with voice...
Old 05-12-2005, 05:55 PM   #6 (permalink)
Commander in Chief
QwertyManiac's Avatar
Then try this ...
Start > Set Program Acess and Defaults and make ur browser default there
Note : Set Program Acess and Defaults Also available in Add/Remove Programs' side tab
Harsh J
www.harshj.com
QwertyManiac is offline
Old 05-12-2005, 08:30 PM   #7 (permalink)
Even i faced the same issue of not being able to recieve offliners. its has no real solution and will get alrite after sometime by its own. do you play yahoo games ?
sabman is offline
Old 03-01-2006, 12:50 PM   #8 (permalink)
softhunterdevil's Avatar
open another yahoo id!
or
use your brother's id
Graphics Portfolio: http://www.redbubble.com/people/reactdevelopers
Music Portfolio: http://www.soundclick.com/shdmusics
softhunterdevil is offline
Old 03-01-2006, 04:51 PM   #9 (permalink)
softhunterdevil, we wud expect more meaningul and logical solutions and u rather not keep increasing ur post with junk!
/legolas
legolas is offline
Old 03-01-2006, 06:12 PM   #10 (permalink)
AMD user for 9 yrs!!
rollcage's Avatar
just a simple query .. i dont do much of a chating
I downloaded the indian version last week but it doesnt have the Voice Call button
Therefore, I have now shifted back to US ed 7.0.2.120
Can anyone tell is there diff?
rollcage is offline
Old 03-01-2006, 08:52 PM   #11 (permalink)
Default Re: problem with yahoo msgr
As your brother and u r sharing the same messenger, i think the problem lies in your id. I mean dat yahoo messenger maintains the profile of each user(id) inside its folder.Default path is " C:\Program Files\Yahoo!\Messenger\Profiles " So somehow the profile may have been damaged. It may be some error on ur computer..so u can try to open it on another computer in a cyber cafe or something. Maybe u can check out the origin of the fault..I mean whether it is happening with ur computer or with the server !!
Another point is that any1 who happens to know ur id and password might be opening it and viewing the messages on ur behalf..Try changing ur password.
Regarding ur second prob, Yahoo Messenger has an option that are enabled by default in the general tab under the preferences window.
In this tab u'll find an option that says " open web links in a new browser window ". U have to check it if its not checked. This problem might be solved thru this.
That's all I can help buddy.....
Old 04-01-2006, 06:02 AM   #12 (permalink)
shakti's Avatar
check out your offline messege settings.
Mr. Infredible
shakti is offline
Old 04-01-2006, 07:40 AM   #13 (permalink)
unless u hav not messed with any settings, these r the only 2 possible reasons...
There are two possible reasons why you may not receive offline messages:
You (or your ISP) are behind a firewall or proxy server. A firewall/proxy server controls what is let in and out of your network. If you think you are behind some type of security protection, please contact your network administrator (if you are at work) or your ISP (if you are at home) to help you configure your firewall/proxy server.
We are experiencing temporary server problems. If this is the case, the server problem should be resolved within the day.
what firewall do u have?
/legolas
legolas is offline
- by chris
