Old 30-11-2005, 04:36 PM   #1 (permalink)
9437077259
go4saket's Avatar
Default Problem with Zonealarm & Sygate firewall...
Hello Friends!
I am facing a problem with both Zone Alarm 6 and Sygate Firewall.
As for ZoneAlarm, whenever I install this software, I dont know how and why, my system gets stuck. Even if I restart my system, the same thing happens.
As in Sygate, installation is no problem, but as I am using BSNL Broadband connection, my network starts showing "Limited or no Connectivity". I dont understand why this is happening. When I started my Modem (BSNL) for the first time after installing Sygate Firewall, it asked me weather or not to allow this network. I allowed it and still it doesn't allow it.
Please help as to what can be dont to resolve this. Please also suggest me some other good firewall. I am using Win XP SP2.
Thank you.
go4saket is offline
Old 30-11-2005, 05:04 PM   #2 (permalink)
Try Kerio Personal Firewall...
Arun
sakumar79 is offline
Old 30-11-2005, 05:44 PM   #3 (permalink)
9437077259
go4saket's Avatar
How is Norton Firewall??? Is it good enough...
go4saket is offline
Old 30-11-2005, 05:57 PM   #4 (permalink)
Commander in Chief
QwertyManiac's Avatar
Norton Firewall is OK, not good nor bad too, but its heavy on resources...
Harsh J
www.harshj.com
QwertyManiac is offline
Old 30-11-2005, 06:13 PM   #5 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
donno wat the prob is ,
but zone alrm is supposed to be one of the best firewalls available
wonder why ur comp is gettin stuck !!!
so "Qwerty Maniac" lives in Chennai
its rainin so hard there (how r the chances of the first test MAN)
vijay_7287 is offline
Old 30-11-2005, 06:36 PM   #6 (permalink)
Distinguished Member
anandk's Avatar
strange zonealarm is gvng u probls.
uninstall ur one or more firewalls.
disable winxp firewall
download and use ccleaner from www.ccleaner.com to clear residual pc junk.
reboot.
try a fresh default instal of zone alarm.
this thread may interest u
http://personal-firewall-software-re...enreviews.com/
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 01-12-2005, 06:12 PM   #7 (permalink)
9437077259
go4saket's Avatar
Well frndz, I tried Zone Alarm 5.5 and that installes and works fine. God knows whats the problem with ZA 6. Anyways, can any one resolve my problem with Sygate firewall. Why is it not taking my BSNL modem in a proper way..
go4saket is offline
Old 01-12-2005, 06:28 PM   #8 (permalink)
9437077259
go4saket's Avatar
Another problem with ZA is that there are a few sites where if you have ZA activated, the websites are not displayed properly. Now is this a problem with the web hosting company or with ZA. As everything seems to be fine with any other firewall, it looks like the problem is with ZA. One of such site is www.heritageofindia.com
If you have ZA installed, all pictures are displayed as no banner pics but its all fine with any other firewall. To test it, try opening the site with ZA activated and than again with ZA disabled. You can see the difference then.
go4saket is offline
Old 01-12-2005, 06:32 PM   #9 (permalink)
Commander in Chief
Its the same for me... try changing ur privacy settings in ZA panel and allow Banners and Headers and stuff like that...
Harsh J
www.harshj.com
- by chris
