Old 27-11-2005, 06:07 PM   #1 (permalink)
Default BOOT UP PROBLEM
When I boot my pc,before windows screen shows up,the follwing message appears:
windows could not start because the follwing file is missing or corrupt:
<Windows\System32\ntoskrnl.exe Please re-install a copy of the above file
I,however,press the enter key and continue to boot.What is the nature of the problem?
rjagathe is offline
Old 27-11-2005, 07:08 PM   #2 (permalink)
Digitall Charisma
Posts: n/a
A problem of this sort just occured to me a few days back. However I run XP and 2000 and the file of mine which was infected was a ver imp. one in system32\config. Anyway, you must give ur entire configuration and which OS you are using. If it is WinXP then you can use System Restore Facility(through dos) to get your files back, else I can't say now. Don't forget to mention the file system of your hard drive.
Probably its not a virus. Its an os fault if u ask me. Well, do reply and wait for others to help.
Digitall Charisma
Old 27-11-2005, 07:13 PM   #3 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
The file u mentioned "<Windows\System32\ntoskrnl.exe" is the file, which required during the boot time.
And somehow it has been deleted?
What u can do is:
1.) Either repair ur windows using Setup CD
2.) Goto "Windows\System32\Dllcache" folder and copy the ntoskrnl.exe file to "Windows\System32" folder
3.) Extract the ntoskrnl.exe file from the Setup of windows XP using Extracter utility like WinRAR
4.) d/l ne boot screen from sites that provide these and copy the file in "windows\system32" folder ( U'll get a new boot screen too )
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 27-11-2005, 07:28 PM   #4 (permalink)
Commander in Chief
QwertyManiac's Avatar
yes, this problem occurs only by changing the boot screen improperly...
U can safely go to a friend's house with the same version of XP as u and copy his piece of "ntoskrnl.exe" to urs via a boot disk
Harsh J
www.harshj.com
QwertyManiac is offline
Old 28-11-2005, 10:03 AM   #5 (permalink)
Better option is to use the repair.
Kannan.
Binary Bits
http://www.binarybits.net
Kannan is offline
Old 28-11-2005, 09:18 PM   #6 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
i think u r better of reparin XP
since it is confirmed tht one file is deleted
repairing might help in settling other problems that the cause for the
damage of this file has created !!!
" "YAHOOOOO POST No --- Ek Sau !!!!!!!" "
vijay_7287 is offline
- by chris
