Old 20-11-2005, 11:37 AM   #1 (permalink)
Default VIRUS Problem !!!!!!!!!!!!!!!!
Hi,
my Pc has been affected with passam.c and passma.d worm which as far as i know is infecting all my .exe files... all the anti virus softwares that i have used only give the option to delete or quarantine the infected files... i cannot allow that as i will loose all my software setups..
Any suggestions on how do i go about curing this infection .. a better way maybe
My os is Winxp with SP1
Thanks,
Robs
robs246 is offline
Old 20-11-2005, 06:23 PM   #2 (permalink)
Distinguished Member
anandk's Avatar
did a google, and one page in portuguese caught may attention. http://translate.google.com/translat...l%3Den%26lr%3D
it appears that deletion is the only option. hope i am wrong, though !
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 20-11-2005, 07:47 PM   #3 (permalink)
deepgeek2's Avatar
Let others find a tech way.
i will pray for you
Pllleeeeeeeeaaaazzzzzzzzzzzzzzzzzzzeeeeeeeeeee add to my Repu points if you think i was helpful.
deepgeek2 is offline
Old 20-11-2005, 08:04 PM   #4 (permalink)
anandk's Avatar
have u spelt it correctly ? or is it passma.b, etc ?
in this case :
try running ewido security suite and avast/avg and adaware or in safe mode.
also this tool claims to repair it http://www.gordano.com/kb.htm?q=2194
or download and use "spy hunter". http://www.enigmasoftware.com/click-...l?hop=official it will ask you to register if u want to remove the infection. pm me if u need help here.
Microsoft® MVP
anandk is offline
- by chris
