Old 28-10-2005, 11:51 AM   #1 (permalink)
vikasg03's Avatar
Default how can we check whether application is run or not in vb
i want to run 4 applications continuesly in vb by using shell or other commands. But one by one. Means i want 2nd application run only when first completed and so on. Is it possible.?
vikasg03 is offline
Old 28-10-2005, 01:05 PM   #2 (permalink)
If you have vb.net, you can do it as per http://www.devx.com/dotnet/Article/7914. For earlier versions, there is a link in the above site to http://support.microsoft.com/support...s/Q96/8/44.asp and http://support.microsoft.com/support.../Q129/7/96.asp which will give a roundabout way to run programs one by one...
Arun
sakumar79 is offline
Old 28-10-2005, 02:16 PM   #3 (permalink)
alib_i's Avatar
For VB 6 there are usercreated codes .. like
FWait
http://www.planetsourcecode.com/vb/s...=6071&lngWId=1
alibi
-Metallica
alib_i is offline
- by chris
