Computer behaving odd with issues
Results 1 to 19 of 19
Thread: Computer behaving odd with issues
  1. #1
    Wise Old Owl ajayritik's Avatar
    Aug 2007
    Hyderabad
    Default Computer behaving odd with issues
    In the past few days I observe that my computer is behaving weird. Whenever I navigate in Windows Explorer I seem to find the folder name as junk characters. Also whenever I try to access some files on the HDD it takes long time to open. Once it restarted as well.
    Yesterday when I was trying to restart a torrent the computer restarted by itself. Now when I check all the torrent files are missing. This is kind of weird.
    Could there be any problem with Virus or anything. I scanned my PC using Avast but I didnt find anything.
    Popular Gadget Deals
  2. #2
    Everything Parallel harshilsharma63's Avatar
    Jul 2012
    Jodhpur
    Default Re: Computer behaving odd with issues
    Post your complete config and the OS. Install "crystal disk info" and post the "relocated sector cont" value. Also, the check HDD sata (both power and data) cables.
    Intel i3 2100 3.1GHz | EVM 2x2 GB DDR3 RAM 1333 MHz | Intel DH61WW | Seagate Barracuda 500 GB | Corsair CX430v2 | Zebronics Oval | LG E2242C 22" FHD | Logitech MK200 | Seagate Extension 500 GB portable HDD | APC RS-600 UPS | Phillips SHP 2000 | Phillips SHE 3590PP | Nokia X2-00
    There is only one success - self satisfaction.
  3. #3
    Aug 2007
    Hyderabad
    Operating System is dual Windows 7 and Windows XP.
    Uploaded with ImageShack.us
    Two new problems started now
    1. All of sudden browser is getting closed and the wallpaper is being removed from what was set
    2. Some search page called All us is coming even if I change it to blank.
  4. #4
    Oct 2011
    Milky Way
    Hello, harshilsharma63 was right on the dot when he asked you to post the crystal diskinfo - your drive showing "C: D: E:" has a caution - meaning it has probably got some bad sectors, or other issues. Run crystal diskinfo again, click on the part showing "caution: 41*C C: D: E:" and post a screenshot if possible - it will show the actual info. (ur current screen shows info of drives L: & M: only).
    I would strongly recommend you to back up all your data/files on your drives C:, D: & E: as soon as possible since drives once they develop faults can fail at any time. Better safe than sorry
  5. #5
    Aug 2007
    Hyderabad
    Yesterday night all of sudden I got a BSOD.
    BSOD Kernel_stack_inpage_Error
    Also after installing Crystal I got start.search set as my home page which is not going.
    I have around 3-4 HDD's. Three SATA and one IDE. Curently I have only one connected and removed the others. Things look ok except for the home page going to http://start.search.us.com/v/2/?guid={C4AB7BDC-DA70-4F51-B6BC-233DE837AF4E}&serpv=5
  6. #6
    Alpha Geek theterminator's Avatar
    Mar 2013
    Los Santos
    Troubleshooting "Stop 0x00000077" or "KERNEL_STACK_INPAGE_ERROR"
    The article points out that it may be a virus. Download & install trial versions of either ESET NOD32 Antivirus or Norton Anti-Virus 2013 & run all types of scans.
    --- iPhone 4 || Sony Xperia E Dual || Samsung Galaxy Ace Duos
    --- Nexus 7
    ---Intel Pentium G2010 || 4GB RAM || 500 GB WD || Asus NVIDIA Geforce 210 1GB || Philips 19" || ASRock Mobo || Samsung DVD-RW || iBall Cabinet/PSU || Origin ID: theterminator645 || Toshiba Canvio Basic 500GB
  7. #7
    Aug 2007
    Hyderabad
    Quote Originally Posted by theterminator View Post
    I currently have Avast. Should I uninstall it before installing this?
    Does anyone have any suggestions on how to remove this start.search.us.com from being set as home page?
  8. #8
    Mar 2013
    Los Santos
    Quote Originally Posted by ajayritik View Post
    Yes. You must first uninstall Avast as two anti-viruses cannot co-exist in the same operating system.
    See if something of that type (start.search.us.com) is listed in Control Panel-->>Programs-->>Programs And Features window. If it's there, uninstall it. If not, tell us which browser you're using.
    --- Nexus 7
  9. #9
    Aug 2007
    Hyderabad
    I have used the steps given in the link Remove Search.us.com Toolbar (Uninstall Guide)
    but still the problem persists.
  10. #10
    Moving dashing.sujay's Avatar
    Nov 2009
    New Delhi
    Which browser are you using?
    And I personally doubt it's a case of virus. Try ESET.
    Rules !!
    DropBox: Get .5GB free
    Vaio CB35
    Prized possession
    Asus U32U ATH M20 Asus RT-N13U B1 Razer DA Young Duos
    Vaio CB35 Review
    How fast can you type?
    Quote Originally Posted by axes2t2
    Before working on a master piece you have to first master the pieces.
  11. #11
    Computer Addict meetdilip's Avatar
    Apr 2009
    Do a clean install, as doubted above it could be a virus.
  12. #12
    Mar 2013
    Los Santos
    That article explains everything what is needed. If you have followed all the steps mentioned then the problem must go. Download & Install above recommended anti-viruses & run scans now.
    --- Nexus 7
  13. #13
    Aug 2007
    Hyderabad
    Quote Originally Posted by dashing.sujay View Post
    Mozilla. But the problem happens in IE and Chrome as well.
    Quote Originally Posted by meetdilip View Post
    Clean install of AV you mean?
    Yes as suggested by you I have gone ahead and uninstalled Avast and have installed Norton trial period. I need to do Live Update and do system scan once.
    One thing I wanted to check with you all folks does having 4-5 HDD's running all at one go create any issues. Especially during summer.
  14. #14
    Human Spambot Zangetsu's Avatar
    Jan 2008
    Soul Society
    Nope.
    HTC One V | Nikon D3100 | Apple Ipod Touch 4G | SM ES18 | Casio Edifice EX106 | WD My Passport 1 TB | Seagate Backup Plus Slim 500GB
  15. #15
    Nov 2009
    New Delhi
    First make sure you remove the installed "culprit" ad-on, then only you will be able to change the settings.
    Fresh install of OS.
    Rules !!
    Vaio CB35
    Prized possession
    Vaio CB35 Review
  16. #16
    Aug 2007
    Hyderabad
    Got Live Update done for Norton and did a full system scan. Found some trojan etc but the problem still persists with the browser redirecting to the said page.
  17. #17
    Nov 2009
    New Delhi
    ^Did you followed my last post?
    Rules !!
    Vaio CB35
    Prized possession
    Vaio CB35 Review
  18. #18
    Aug 2007
    Hyderabad
    Will have a fresh install done of the OS. Need advice on the below two questions.
    1. Which AV should I install should I go for Firewall as well? Stick with avast?
    2. Is having 4-5 HDD's connected all at same time good or not?
  19. #19
    Jun 2011
    Roorkee
    1. Avast is good enough.
    2. If your PSU has the strength to power it, then what's wrong with having any number of HDDs.
    After silence, that which comes nearest to expressing the inexpressible is music.
