Old 23-10-2005, 04:07 PM   #1 (permalink)
Default HELP!!!
i'm new into computers. so i dont know wat all hw specifications i must give of my system for u to crack my problem. anyway here's wat i feel should be included-
i've an AMD AthlonXP 2600+, 1.92GHZ 640MB DDR RAM system, display : Plug n Play monitor on VIA/S3G UniChrome IGP. the prob i have is that, wen i play games like GTA 3, GTA Vice City, Serious Sam, NFS U1, the games hang n an error msg is shown that my display driver has stopped working... but most other games work fine. plz tell me what the problen is??? should i get a graphics card or is it some problem with my system??? plz help!!!
pathalaravanan is offline
Old 23-10-2005, 04:27 PM   #2 (permalink)
try updating the drivers, i think ur config is decent enough to play these games.
Shwetanshu Srivastava
shwetanshu is offline
Old 23-10-2005, 05:46 PM   #3 (permalink)
Default Re: HELP!!!
your Configs are great no probs there, just as ^ said, download fresh drivers for your display and graphics card.
Master Search Engine Optimization Tutorial.
Sitez::
1) Broadband-O-Sphere
2) [url=http://techbulletin.net]TechBulletin[url]
Retro is offline
Old 23-10-2005, 07:10 PM   #4 (permalink)
cybermanas
Posts: n/a
@pathalaravanan
How much is your memory is shared by your onboard VGA?Try increasing it from BIOS.NFSUG1 requires a minimum of 32MB shared memory.Try updating your drivers.If none of hese work my suggestion is to go for a good 256MB graphics card.
Old 24-10-2005, 09:22 PM   #5 (permalink)
nd howz ur memory divided into ????
512 MB + 128 MB ?????
try removing the 128MB chip if this is the case and then try running the game....
grinning_devil is offline
