Old 23-10-2005, 12:05 PM   #1 (permalink)
Default net connection
i have Win XP
how do i enable a net connection in the guest account?
i have it in the administrator account. But it does not show up in the guest account!
rowdy8344645 is offline
Old 23-10-2005, 07:41 PM   #2 (permalink)
Default Re: net connection
Originally Posted by rowdy8344645
i have Win XP
Do you mean it does not show up on the desktop in your guest acc.?
Go to Control Panel (classic view) --> Network connections. Can you see you connection there?? If yes, create a shortcut by rt. clicking on it selecting the appropriate option.
Keith
Keith Sebastian is offline
Old 23-10-2005, 09:14 PM   #3 (permalink)
choudang's Avatar
Log in to your Guest A/c ---> create the shortcut from Network connection [control pannel or start menu]
choudang is offline
Old 24-10-2005, 09:18 PM   #4 (permalink)
guest acount....oooops never used it !!!!!
but as keith says....just the shortcut is missing ... !!
grinning_devil is offline
Old 27-10-2005, 07:44 PM   #5 (permalink)
Even i thought of that, but in the network connections, if you rightclick on the connection, the enable option is greyed out!
BTW its an MTNL tri-band connection, so its a LAN.
Is there an option in WinXP to "enable Net Connections in Guest account" or something like that?
