Old 19-10-2005, 07:42 PM   #1 (permalink)
Default Media player problem
I use WMP to play all my videos.The problem is that it plays all videos at about 70% of its natural brightness.(The other players play those videos correctly).I have reinstalled WMP but the problem persists.Please help as i have to change the brightness while playing each file,it dosen't even store that setting.
Thanks
skrbhatt is offline
Old 19-10-2005, 07:56 PM   #2 (permalink)
champ_rock
champ_rock's Avatar
try adjusting ur monitor........ or use some other software... what is stpping u to WMP
Registered Linux user number 400618
champ_rock is offline
Old 19-10-2005, 08:05 PM   #3 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Which version of WMP r u using?
Did u try to reset the color, brightness, etc settings in Enhancements settings?
http://www.AskVG.com/
Vishal Gupta is offline
Old 19-10-2005, 08:36 PM   #4 (permalink)
Make sure you have the Video Overlay settings adjusted in your video driver settings.
Control Panel > Display > Settings > Advanced > (this part will differ based on your video card).
Keith
Keith Sebastian is offline
Old 17-07-2007, 10:07 AM   #5 (permalink)
Boom Boom Boom
cooldudie3's Avatar
Default Re: Media player problem
ur pretty much right, what the use of WMP it can't play all kinds of files
i recomend realplayer quicktime or vlc media
I'm back! Gimme a hugggggg...
cooldudie3 is offline
Old 17-07-2007, 02:54 PM   #6 (permalink)
Microsoft MVP
^^ Pls stop bumping old threads. It was approx. 2 years old thread...
Old 17-07-2007, 08:30 PM   #7 (permalink)
slugger's Avatar
maybe hong kong ka connexion is so fast dat by d time d guy clicked read and posted 2 years have passed
maybe china not allocatin' enuf bw 4 hong kong
slugger is offline
