Old 02-10-2004, 07:36 PM   #1 (permalink)
QA Juggler
saROMan's Avatar
Default Help Badely Needed.......My Xp is currupted...
my Xp is currupted.....to reduce the load on my machine..i switched to windows classic theme ...after that my screen went Black..........nothing except the icons on desktop r visible........all the windows /menus have dissappered....may be bkoz i uninstalled styles Xp fm my pc..this may have corrupted my theme /msstyle files...so i used the expand command to extract luna.theme & msstyle file fm my XP cd ....but Vain.....as a final option i deleted all the files in my \resources\themes folder & reeboted....but nothing.........i hav tryed booting in VGa / Last known config...but nothing.......if i boot thru safe mode..........it works perfectly fine...........can any 1 plz help me.....coz i am not in a mood to reinstalled my xp (coz i hav tweaked for max performence) ...plz help me........
8-) सारोमान :!: :!: :!:
saROMan is offline
Old 02-10-2004, 08:14 PM   #2 (permalink)
Default try this
just reinstall stylexp and then check with ur recources foldr...may be u can help urself then..
__...:::---*Keyboard Cowboy*---:::...__
whistler is offline
Old 02-10-2004, 08:28 PM   #3 (permalink)
the same happened to me, but try this > goto start > open Style XP and switch to different theme & apply the theme, hope this shud fix the probs... !
Vande Mataram - Two words that became a Fiery War Cry and Electrified the nation towards Freedom. A mantra that instills a sense of Pride and belonging.
go4inet is offline
Old 02-10-2004, 08:36 PM   #4 (permalink)
QA Juggler
saROMan's Avatar
Default ?????????
its black not blank..........i cant do any thing,...imagine tat all ur toolbar ,windows , menus, text are black......u cant see nothing u cant do any thing........ by clicking on the place where ur start button is placed u have to use ur imagination tat where can the shutdown button can be if u donno where the restart button is on ur machine..........did u get me now....????????
if this still dosent make any sence to u...will try to print screen open pbrush (win key + r , type pbrush ...hope its opened press ctrl V ..press alt F&s type the location..copy it on my 98 part ..and then post it here)..............do i have done any thing that bad to u tat u wann me to go thru all this mess........
saROMan is offline
Old 02-10-2004, 09:02 PM   #5 (permalink)
Default try this
what about safe mode (VGA MODE)
r u able work in it...with start button
whistler is offline
Old 02-10-2004, 09:07 PM   #6 (permalink)
QA Juggler
saROMan's Avatar
but what next......??????/ to do ..i dont have a damn clue......i have tryed changing resolution to 640*480 , 16 Bit ..after reboot....same old story....
saROMan is offline
Old 02-10-2004, 09:38 PM   #7 (permalink)
Default ok..
then doa stylexp reinstall from there...or try to do a restore if u have not disabled it..
whistler is offline
Old 02-10-2004, 09:44 PM   #8 (permalink)
Davislav Ivanuiz!!!
Kl@w-24's Avatar
U say that everything is fine in safe mode ? Can u see th icons on ur desktop in normal mode? If not, then u hv probably lost ur display driver. Try booting into safe mode and reinstall th drivers for ur display card.
I was here when the forum's swear filter kept bleeping out the word 'FUNK'. :crazy::censored::eeksign:
www.abhi247.com | The Photohblog A Little Lunacy! [v3]
Flickr!
Kl@w-24 is offline
Old 02-10-2004, 10:20 PM   #9 (permalink)
I dont know if this will work - Tweak UI for XP has under the Repair section an option "rebuid icons". This seems like something that may help.
richard nightly is offline
Old 02-10-2004, 11:21 PM   #10 (permalink)
Default ok..
whistler is offline
Old 02-10-2004, 11:26 PM   #11 (permalink)
sujithtom's Avatar
Why don't you use the system restore feature that comes with XP
http://geeksbay.monzilla.info - My Tech Blog :)
sujithtom is offline
Old 02-10-2004, 11:32 PM   #12 (permalink)
mariner's Avatar
reinstall !!
mariner is offline
Old 02-10-2004, 11:47 PM   #13 (permalink)
try a Repair Install - you get corrupted files updated and this maintains your current setup.
Old 03-10-2004, 12:22 AM   #14 (permalink)
QA Juggler
saROMan's Avatar
well thx a lot pple...i think the only optn i hav is to restore my system..thru safe mode......
any wayz.......just to show u ..this is wat my Xp looks like right now.....
saROMan is offline
Old 03-10-2004, 12:27 AM   #15 (permalink)
hey... thats how my xp looked tooo.... goto start menu using ur keyboard or mouse and start style xp and just chnage the theme frm ur current one. and it shud fix !
go4inet is offline
Old 03-10-2004, 12:30 AM   #16 (permalink)
aadipa's Avatar
try sfc
u will need to go to recovery console for it.....
1 aadi + 1 aadi = 1 full ;)
aadipa is offline
Old 03-10-2004, 03:03 PM   #17 (permalink)
QA Juggler
saROMan's Avatar
hey ppl...system restore just did the trick...........thx a lott.....
saROMan is offline
- by chris
