Old 10-10-2005, 08:05 PM   #1 (permalink)
Karthiksn
kato's Avatar
Default XP not starting!!!
Guys i need ur help XP is not booting in normal mode only booting in safe mode.
It gets stuck even before the login screen shows up please help me.
"Walking the Path of Heaven, The Ruler of All."
kato is offline
Old 10-10-2005, 08:11 PM   #2 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Did u disable ne service?
U can try to repair ur XP, it'll surely solve ur problem!
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 10-10-2005, 08:17 PM   #3 (permalink)
Karthiksn
kato's Avatar
tell me wats wrong i cant figure out.I even restored my pc to a previous date still not working .The problem is that its stopping on the screen bfore login screen the one which has windows XP professional written on it.
kato is offline
Old 10-10-2005, 08:40 PM   #4 (permalink)
deathvirus_me's Avatar
u disabled the boot skin ????
deathvirus_me is offline
Old 10-10-2005, 08:47 PM   #5 (permalink)
Distinguished Member
anandk's Avatar
seems to be some sortofa bootskin problem posibly.
try to boot in 'last known good configuration'.
try to do a system restore.
if they dont help, go to safe mode.
did u install any new applications/ programs recently ? if yes uninstall them.
then check up ur start-up entries. if u can, disable the non-microsoft ones' for the moment. u can use the xp tool, or else install winpatrol (in safe mode itself) and use it.
in safe mode also use 'ccleaner' or other such cleaner to clear ur pc junk.
hopefully it shud help. if it doznt, do revert pls.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 10-10-2005, 08:51 PM   #6 (permalink)
disable start up in safe mode and try booting
aditya169 is offline
Old 10-10-2005, 08:59 PM   #7 (permalink)
Karthiksn
kato's Avatar
ppl i tried booting again in normal mode but it got stuck again i waitred for 20 minutes and it opened.Can anyone tell why has my system became deadslow and why it takes time to load to the login screen.
kato is offline
Old 10-10-2005, 09:23 PM   #8 (permalink)
q3_abhi's Avatar
Have You installed a Service Pack?
Fragging is the key to Success!!!!!
My blog : http://q3abhi.wordpress.com
q3_abhi is offline
Old 10-10-2005, 09:28 PM   #9 (permalink)
Karthiksn
kato's Avatar
no it makes the system run at snails pace and everything gets stuck so never installed a service pack
kato is offline
Old 10-10-2005, 10:57 PM   #10 (permalink)
what did u do different that ur xp stopped booting ?
what was the last thing u worked on ?
also boot into safe mode and run system restore and restore to a point ur system was working fine
No Mercy, No Limits.
theraven is offline
Old 10-10-2005, 11:11 PM   #11 (permalink)
Karthiksn
kato's Avatar
raven bhaiya read my earlier posts too i had done system restore and all those things but now the problem is it boots only after nearly 20 mins or sumthing after showing the windows XP professional loading screen.
kato is offline
Old 10-10-2005, 11:50 PM   #12 (permalink)
bang bang!
Chirag's Avatar
Did u install softies like style xp or any softie like that?Try removing that. It also happened with me. I installed style xp and afterwards my pc was taking time to load all the servies.
Chirag is online now
Old 11-10-2005, 12:36 AM   #13 (permalink)
ok i had to skip a few posts dude !
but temme what was it u last worked on before the problem popped up ?
theraven is offline
Old 11-10-2005, 01:02 AM   #14 (permalink)
Commander in Chief
QwertyManiac's Avatar
try repairing ur installation using ur install disk or boot nto safemode and reset all the theme files
Harsh J
www.harshj.com
QwertyManiac is offline
Old 11-10-2005, 01:20 AM   #15 (permalink)
Karthiksn
kato's Avatar
i uninstalled the windowsblinds some days ago and even removed many things and the last thing i was working on was katana mod.I was trying to unzip the files but it always kept getting stuck so i killed the processes and shutdown my pc as i had to go out.
kato is offline
Old 11-10-2005, 01:31 AM   #16 (permalink)
hmm one of those moves screwed something up
but a system restore SHOULDVE worked in that case
so heres what ya do ,..
run sfc /scannow from start => run
it'll ask for xp cd .. pop it in
theraven is offline
Old 11-10-2005, 01:46 AM   #17 (permalink)
Karthiksn
kato's Avatar
tried it still no hope can u tell me something there was a registry file in the katana mods zip file thuogh i never unzipped that file could it have done the damage.
As there is no need for registry file in max payne mods
kato is offline
Old 11-10-2005, 11:44 AM   #18 (permalink)
Ur problem has no solution.Backup ur data and reinstall xp.If u have disabled any services enable them and try tweaking ur registry.
sudeepg123 is offline
Old 11-10-2005, 01:13 PM   #19 (permalink)
Karthiksn
kato's Avatar
XP now starting with very less problems though some of theof the programs are taking a lot of time. As raven had said i took time restored the system again and repaired it again it did the work but still computers a bit slow. Thanks everyone for the help as i can now boot without any problem. Thanks everyone again.
Gr8 my hundredth post and that also went in asking about my silly computer.Gr8 now atleast i feel i got hundred posts.
kato is offline
Old 11-10-2005, 03:18 PM   #20 (permalink)
The Incredible's Avatar
wat r those few problems. anything except late-loadin program problems???
CONGRATULATIONS! Hop u'll reach the next title soon.
Best Of Luck.
The Incredible is offline
Old 11-10-2005, 04:29 PM   #21 (permalink)
Karthiksn
kato's Avatar
less problems mean that it takes sometime to load login screen(negligeable) and that programs running a bit slow.
And i have this problem though old i installed flash player many times but i cant see it in the add and remove programs list.
kato is offline
Old 11-10-2005, 05:54 PM   #22 (permalink)
mariner's Avatar
back up and reinstall.works every time !
mariner is offline
- by chris
