Old 09-10-2005, 05:19 PM   #1 (permalink)
Default firewall problem in win xp
Recently i installed zonealarm pro 6 on my computer after the installation
a message appeared to restart the computer as usual i restarted my pc
after the windows xp booting sign logon screen not appeared instead there
is a blank black screen.
How to solve this problem and can i install this
firewall if not which is the best other than zonealarm
please help
appu
gvrappu is offline
Old 09-10-2005, 05:54 PM   #2 (permalink)
Restart your computer in safe mode, uninstall zone alarm and switch back.
(If it doesnt work, use windows recovery and recover to a previous date)
Now when you login in normal mode, download a new copy of zonealarm from its website and install it.
Zone alarm is the best and user friendly.
techiways is offline
Old 09-10-2005, 06:08 PM   #3 (permalink)
Edit by Deep: If you do not know the answer then dont reply..
rajas700 is offline
Old 09-10-2005, 09:40 PM   #4 (permalink)
anomit's Avatar
Originally Posted by rajas700
Go with NORTON PERSONAL FIREWALL for better..
I think the person concerned did not ask for your advice on firewalls....
And that problem for me occurs even after installing the updated version. There is no way but to uninstall it from Safe Mode
Don\'t SYN me, I'll SYN you. :p
anomit is offline
Old 09-10-2005, 09:51 PM   #5 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
Are you on LAN? Cause there is this thing with the latest ZoneAlarm and LANs.
kalpik is offline
- by chris
