Old 03-10-2005, 10:17 PM   #1 (permalink)
Default is Win XP pro Bluetooth ready
hi guyz
i want to know whether Win XP Pro (without any service packs) is bluetooth ready?
if not, then is there any way other than installing the service packs.
(like some tweaks, etc......)
setharsh is offline
Old 04-10-2005, 02:12 AM   #2 (permalink)
mariner's Avatar
if u mean the drivers than yes xp pro does have bluetooth drivers and u dont need to install them.they will automatically installed when u connect ur bluetooth device !
mariner is offline
Old 04-10-2005, 09:18 AM   #3 (permalink)
but the book Win XP bible says that SP2 is necessary for bluetooth to work
setharsh is offline
Old 04-10-2005, 12:16 PM   #4 (permalink)
Netjunkie's Avatar
Win XP initially had no built in support for Bluetooth devices. XP SP2 adds this feature.
Netjunkie is offline
Old 04-10-2005, 12:34 PM   #5 (permalink)
XP's bluetooth is crappy. it detected my usb dongle and refused to wirk with it. i had to manually change the drivers in hardware. my point is if it cant do it then why set the drivers automatically?
srijit is offline
Old 04-10-2005, 07:15 PM   #6 (permalink)
Technoholik !!
Tech&ME's Avatar
Windows XP SP2 now has native support of Bluetooth v2.0
If you are installing old version of bluetooth hardware, some problem may be there but not necessararly.
[Desktop]
[Laptop]
Tech&ME is offline
Old 04-10-2005, 10:51 PM   #7 (permalink)
harsh bajpai
Posts: n/a
sure, but only after service pack 2.
- by chris
