Results 1 to 22 of 22
  1. #1
    May 2006
    Tuticorin
    Exclamation Help regarding K9 web protection program
    I have installed K9 web protection parental software in my desktop and had configured it to block porn and some other category websites. My brother has a laptop. Is there a way to block the same category websites on his laptop too, other than installing K9 in it [ofcourse only he knows the password for his laptop]. We both share a single BSNL broadband connection.
  2. #2
    Project Halcyon V2.1 tkin's Avatar
    Aug 2008
    Hyderabad, India
    Default Re: Help regarding K9 web protection program
    Install a hosts file on his PC:
    BadHosts File
    2600k/Z68VPro/Vengeance/U12PSE2/TX750v2/1TB.Black/DRWB5ST/HAF912+A
    M35/PortaPro/E30/Optimus.L9/Siberia/5800XM/FZ150/SH14/FiiO.E6
    Dell.15R/Ci3.3110m/7670m/ALVS4621/Funbook/Ferox
  3. #3
    Alpha Geek reniarahim1's Avatar
    Jan 2008
    Bangalore(KA) / Cochin(KL) , IND
    why you want to break into into his personal space
    Dell Studio 1555 - Intel Core 2 Duo P8600 @ 2.40 GHz, 3 GB RAM, 500 GB HDD, ATI Mobility Radeon HD 4500 | PC - Intel Pentium G620 @ 2.60 GHz, Intel DH67CL, 4 GB RAM, 500 GB HDD | Samsung Galaxy S Plus - 1.4 Ghz, 512 MB RAM, 16 GB Internal, 8 GB SD
  4. #4
    Aug 2008
    Hyderabad, India
  5. #5
    Rusted... dashing.sujay's Avatar
    Nov 2009
    Bhopal
    Since you guys share a single connection, best option is openDNS. I used it and its good.
    FAQ + answers for new members (Read before asking / messaging any moderator for any query)
    Drop Box: Get 500MB free
    Quote Originally Posted by axes2t2 View Post
    Before working on a master piece you have to first master the pieces.
    Sony Vaio CB35 Asus U32U ATH M20 Fiio E6
    Sony Vaio CB35 UnBoxing & Review
    How fast can you type?
  6. #6
    Aug 2008
    Hyderabad, India
    Quote Originally Posted by dashing.sujay View Post
    He wants to block connections, not UNblock them.
  7. #7
    Daemon Prince of Tzeentch DeSmOnD dAvId's Avatar
    Apr 2005
    The Eye Of Terror
    Agreed.
    I prefer Norton ConnectSafe DNS. It's free for home use and blocks pr0n and malware sites. You don't have to install anything, just put the DNS addresses into your router.
    "The way I see myself, so confused, so sophisticated."
    Petition to Valve to start a Dota 2 server in India
    My Guitar Videos On Youtube
    Steam : Meshuggah Guy
    My Blog : The Pandemonium
  8. #8
    May 2006
    Tuticorin
    Quote Originally Posted by tkin View Post
    BadHosts File
    Does installing this script require admin rights.? If yes, i can't do it. Any other way.?
    Quote Originally Posted by reniarahim1 View Post
    My broadband plan is Home 500 combo. 1.5GB limit per month. My brother all the time uses Facebook and Youtube viewing videos..etc. That's the reason
    Quote Originally Posted by DeSmOnD dAvId View Post
    I will try this and report back. Thanks for the tip.
  9. #9
    Master KOD3R nbaztec's Avatar
    Sep 2010
    New Delhi
    Either way, it's a wrong way to fix the problem. You should instead try to come to means with him (surely you must be adults about it). And changing the DNS is the safest/quickest way.
    AMD Phenom II X6 1055T|MSI 880GMA-E45|MSI 7770|2x2 Corsair DDR3 1333MHz|CM Elite 310|Corsair CX400W|DELL ST2320L
    Myself @ nbaztec.co.in
    Build Your Rig! (XBlade) @ nbaztec.co.in - Build Your Rig!
    My Inner Artist @ nbaztec.co.in - Designs
  10. #10
    Nov 2009
    Bhopal
    huh.?
  11. #11
    Sep 2010
    New Delhi
    huh.?
    Think he misunderstood you. OpenDNS works fine for blocking sites too.
  12. #12
    Aug 2012
    Mumbai
    for using bad file host ..he may have to log on to his laptop right..???
  13. #13
    Nov 2009
    Bhopal
    ^Just use OpenDNS and he won't be able to even figure out what's blocking. You just need access to modem/router. And the best part is you can control it (modify/remove restrictions) from any part of the world. If you need I can give a tutorial on how to do it.
  14. #14
    Alpha Geek sharang.d's Avatar
    May 2012
    Pune
    ^Gimme please
    Intel Core i5-2500k ASUS P8Z77-V PRO CM Hyper 212 EVO G.Skill 1600Mhz 4G X 2 Sapphire HD 7870 Seasonic S12II 620W Corsair Carbide 400R Microsoft Sidewinder X6 Logitech G400 LG E2381VR Razer Goliathus Control Edition (Small)
    Additional Cabinet Fans CM Blue LED silent fan 140mm Silverstone AP121 120mm
  15. #15
    May 2006
    Tuticorin
    Unhappy Re: Help regarding K9 web protection program
    I have used OpenDNS. But i faced an issue with it. My BSNL Broadband assigns IP dynamically. Hence i need to update my IP each time a new connection is made. For this, there is a program called OpenDNS Updater which requires Admin rights to be installed in his laptop. Even if i did it (through some way), he can uninstall it easily. I faced this issue when we shared the desktop. I installed it and made restrictions but he uninstalled it to browse the restricted sites. (Don't ask me why i shared the desktop admin password with him, the real culprit is my dad..
  16. #16
    Nov 2009
    Bhopal
    Quote Originally Posted by rakesh-the gilli View Post
    You have to use DNS updater in order to use OpenDNS. Why do you switch off the modem in first place? Plus the main question is why does your bro removes it? Does he knows about it? If yes, then you're doomed, or tell him not to remove it as its something installed by net company and required for good functioning of net.
  17. #17
    May 2006
    Tuticorin
    This is what i did exactly.
    Does all BSNL limited connection owners keep their modem switched on all day.? When not in use, we switch it off right.?
    Before installing the DNS Updater to block youtube, dailymotion and other streaming sites, he use to watch those. After installing DNS Updater, he came to know that some websites had been blocked. He searched for the program (DNS Updater) that made restrictions and removed it. Nowadays every possible solution to bypass restrictions such as this are available in internet isn't it.?
    He is a 3rd year engineering student. I don't think this answer will let him believe it.
  18. #18
    Dec 2010
    No matter what you do, he can always circumvent it - You don't have access to his terminal (actually you can "get" that, since you are both on the same network, but "getting" it is a different issue ) , cant inject and protect the hosts and also can't use opendns parental controls.
    You could try url filtering in the router, provided your router has that option but it would only stop him as long as he does not find a proxy you forgot to block. (but at least its a viable deterrent to some extent, since proxy speeds would be somewhat lesser)
    My suggestion, ask him politely not to visit these sites, back that up with a threat to permanently disconnect him from the bb, and finally filter his mac if he connects wirelessly or disable the lan port if he connects with cable.
  19. #19
    Nov 2009
    Bhopal
    ^They're using the same pc.
    Before installing the DNS Updater to block youtube, dailymotion and other streaming sites, he use to watch those. After installing DNS Updater, he came to know that some websites had been blocked. He earched for the program (DNS Updater) that made restrictions and removed it. Nowadays every possible solution to bypass restrictions such as this are available in internet isn't it.?
    You can try disabling add or remove programs. (don't kill me when he bypasses it )
    You don't need to switch off your modem even for 6 months! (I never did it). And it doesn't eats up your bandwidth.
  20. #20
    Dec 2010
    Really?
    Edit: Ok, I re-read the whole thing again - guess you are talking about the part where he says, they shared the desktop at some point in the past - but I thought that meant before the brother got a laptop of his own.
  21. #21
    Nov 2009
    Bhopal
    ^Yes, I meant for the later part and had almost forgot about the laptop.
  22. #22
    May 2006
    Tuticorin
    Is it.? You are lucky. Some 8-9 months back I use to switch the modem on and go to sleep by 11 after scheduling the desktop to start downloads by 2.10 am. The surprise came when i got my bill. Unaccounted MB's (in hundreds per hour !!) added up. When i lodged a complaint and inquired into it, they(so called BSNL officials) asked me to switch it off when not in use. They checked for changes with respect to MAC Address of my modem but as the MAC address was not changed in their records they advised me so. Do you know, once i complained them of low broadband speeds, they asked me to increase my RAM in order to get higher speeds.
    Quote Originally Posted by Mario View Post
    You could try url filtering in the router, provided your router has that option but it would only stop him as long as he does not find a proxy you forgot to block. (but at least its a viable deterrent to some extent, since proxy speeds would be somewhat lesser) My suggestion, ask him politely not to visit these sites, back that up with a threat to permanently disconnect him from the bb, and finally filter his mac if he connects wirelessly or disable the lan port if he connects with cable.
    Any other solution with respect to changes in modem level, say like Norton Connect safe.?
    You got it right this time
    Update: I tried with Norton ConnectSafe. Norton ConnectSafe works only if we change to their mentioned IP address under TCP/IP property settings and not on modem settings. I changed my DNS relay and DNS Client in modem page with Norton ConnectSafe IP's. But still porn sites (for eg) loaded. Only when i changed my TCP/IP property settings, a warning came.
