Old 26-09-2005, 06:13 PM   #1 (permalink)
linardni's Avatar
Default Plugin not showing
I have downloaded lots of them...but can't use them. I have decompressed and put them in the plugin folder under photoshop.....till the filters are not shown under the filter menu. what to do?
linardni is offline
Old 26-09-2005, 06:16 PM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
are you sure u have downloaded the rite version for ur version of Pshop ?
coz sometimes its not compatible with other versions.
Harsh J
www.harshj.com
QwertyManiac is offline
Old 26-09-2005, 06:58 PM   #3 (permalink)
linardni's Avatar
nope i am not sure of it...
linardni is offline
Old 26-09-2005, 07:18 PM   #4 (permalink)
Commander in Chief
wat is ur PShoP version ?
Try googlin on em'
Harsh J
www.harshj.com
Old 27-09-2005, 02:57 PM   #5 (permalink)
linardni's Avatar
thanx i will try
linardni is offline
- by chris
