Results 1 to 8 of 8
Thread: How do I change the audio codec?
04-07-2012, 06:11 PM #1
Okay guys, as you might be knowing that I am already looking for changing a few rmvb files to a version or a format which my TV's can play (I have one samsung and one Sony LED) so I was just trying a few things and now something like this happened: I put my rmvb file in the pen drive and connected the pen drive to my samsung tv, it did not read the rmvb videos, but once I changed the extension from ".rmvb" to ".MPG" or ".MP4", my tv was able to read the video files and also understand its video codec but not the audio.
So my question is how do I change the audio codec WITHOUT CONVERTING my video using any video or audio converter? Just so that my TV starts reading the audio as well.Up For Sale:
Hindi and English Movies and Audio CDs for Sale (dirt cheap)
Free Printer refill INK (black) for giveaway, half bottle.
04-07-2012, 06:45 PM #2
Re: How do I change the audio codec?
RMVB uses a video codec which is a version of H264 codec and most of the current LCD TVs can handle H264. But the audio codec is Real Audio which is a different format and can't be understood by most of TVs.
What you need to do is extract the audio stream, convert it to MP3 format and then Remux it with the video.
Use MediaCoder for this purpose. Add the video to MediaCoder list, set the Video Codec to 'COPY' and And Audio codec to MP3 with 144 Kbps Bitrate. Set the output format to Mp4. Now convert it. The output will be a MP4 file with H264 Video and MP3 audio. You can now play it on your LCD TV properly.AMD FX 8350 @ 4.5 GHz|16 GB RipjawX 1873 MHz CL10 @ 1.6V|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|Sapphire HD 7950 VApor-X OC with Boost|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|LG D2342P Cinema 3D Display|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Razer Megalodon 7.1 Headset|CM Hyper 212 Plus|APC1.1KVA| Moto Defy Plus with CM 10.1 JB 4.1|HCL Me Y2 Tab (rooted)] XOLO Q800 with Ultimate V2 JB 4.2.1| Galaxy Tab 2 P3100
04-07-2012, 06:49 PM #3
rename the .rmvb extension to .mp3 & it will read audio codec
jokes apart
you cannot change the audio without using any converter & renaming worked because the TV supports the .MPG/.MP4 codec & not .RMVB codec which is by Real Media.
as for why audio was not working because audio is cook audio which is specially used in rmvb files
Hence,u have to convert the file to supported file type by your TV
HTC One V | Nokia 5233 | Nikon D3100 | Apple Ipod Touch 4G | Sound Magic PL21 | Sound Magic ES18
04-07-2012, 07:02 PM #4
Well the only reason why I don't want to convert using any converter is because it will take me a lot of time to convert as there are over 200 files.
@Cilius can you tell me the method which you have told, how much time will it take for converting each video to a compatible form and secondly is MediaCoder free or shareware?Up For Sale:
04-07-2012, 10:39 PM #5
He already told you about the process which you have to take to convert he audio to a compatible format. Mediacoder was a freeware. But now isn't. But you can get old freeware versions from here: MediaCoder -> History & Old Downloads | Software - Digital Digest
How much time will it take? You will have to test it by trying to do it with a single file first!
Sometimes in life.. you just can't take shortcuts. That's why you have a PC
04-07-2012, 11:22 PM #6
Yeah I agree that we can't always take short cuts but seriously converting 200 video files is hell of a task.
Secondly I tried what Cirius said and the time for the task is nearly as much as converting the video file, so I see no point in this procedure as well.
Thanks for all your help guys.Last edited by sam9953; 05-07-2012 at 12:17 AM.
Up For Sale:
05-07-2012, 01:05 AM #7
Since, the video is playable at your TV, you don't need to convert the video, just audio conversion will do. For a 1.5 Hrs of movie, the time for only video conversion at mp3 format is around 20 to 30 mins max.
BTW, MediaCoder is still free, it not open source now. Initially it was Open source too.
And I mention that while converting, make sure the Video Conversion mode is just COPY VIDEO and the audio conversion mode will have the Mp3 settings. In that case, MediaCoder or any encoder having this feature won't convert the video, it just pass the source Video stream and then internally remux it with the converted audio stream.AMD FX 8350 @ 4.5 GHz|16 GB RipjawX 1873 MHz CL10 @ 1.6V|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|Sapphire HD 7950 VApor-X OC with Boost|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|LG D2342P Cinema 3D Display|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Razer Megalodon 7.1 Headset|CM Hyper 212 Plus|APC1.1KVA| Moto Defy Plus with CM 10.1 JB 4.1|HCL Me Y2 Tab (rooted)] XOLO Q800 with Ultimate V2 JB 4.2.1| Galaxy Tab 2 P3100
05-07-2012, 01:50 PM #8
Up For Sale:
Audio / Video Codec support for Nokia ?
By GERMZ in forum Mobiles and TabletsReplies: 2Last Post: 18-11-2011, 11:15 PM -
how to update audio codec in laptop
By vikasg03 in forum Laptops and NetbooksReplies: 4Last Post: 05-11-2011, 10:11 AM -
Problem with Audio codec
By windchimes in forum Software Q&AReplies: 4Last Post: 27-04-2008, 11:26 AM -
Which is the best audio/video codec pack available ?????
By coolendra in forum QnA (read only)Replies: 18Last Post: 27-11-2005, 08:48 PM -
audio codec
By legolas in forum QnA (read only)Replies: 4Last Post: 29-04-2005, 08:18 PM
LinkBack URL
About LinkBacks
