Results 1 to 15 of 15
Thread: Urgent help required!
27-05-2012, 08:17 PM #1Right Off the Assembly Line
- Join Date
- May 2012
- Posts
- 5
Hi guys! My laptop used to work perfectly fine until one day, it started lagging very badly. I re-started it but the problem persisted. I re-started it again and then it worked fine. After some time, it again started lagging. I checked up on TASK MANAGER and found CPU usage to be 100%! I suspected it was because of browser overload as I was using 3 browsers at a time. But even when I use 2 browsers, it occurs. Is the problem related to Firefox? It's not a virus as I have a fully licensed Norton Internet Security 2012. Please suggest me solutions as it lags pretty badly!
My Laptop Config:-
Dell Latitude E6410
CPU - Core i5 M 540 2.53GHz
RAM - 2.00 GB
GPU - NVIDIA NVS 3100M
OS - Windows 7 Pro (32-bit)
27-05-2012, 08:24 PM #2
Re: Urgent help required!
> do a virus check with updated anti virus, do a malware check with antimalware.
> are you using zonealarm firewall ?
from task manager > processes tab, can you tell what process is taking most cpu % ?
27-05-2012, 08:29 PM #3Right Off the Assembly Line
- Join Date
- May 2012
- Posts
- 5
I have NIS 2012, so I expect pretty high security.
TASK MANAGER lists the top 3 processes as chrome and firefox.
27-05-2012, 09:27 PM #4
Follow these steps:
1. As icebags said, do a scan with latest updated antivirus
2. Defrag
3. Clean registry and temp using some cleaner such as ccleaner.
4. Use process explorer to find out which process is more using the cpu (the process explorer gives more details of the process such as vendor, so that you can decide to kill the process if it is not needed).
5. Give a clear title for your post regarding your problem. (Read the FAQ before posting) and avoid titles like urgent help, help please, because your post might be ignored.Canon Powershot SX130IS
Thinkpad SL400C
Arch linux + dwm = World Domination !
28-05-2012, 11:34 AM #5Wise Old Owl
- Join Date
- Oct 2011
- Location
- Bangalore
- Posts
- 1,052
Try using opera both chrome and firefox are memory devil they eats lots of memory.
28-05-2012, 11:51 AM #6Right Off the Assembly Line
- Join Date
- Apr 2012
- Location
- Pune
- Posts
- 23
Seems like virus as it was not solved after reboot. Update the anti virus definition first, alternatively you can try installing another AV.
Check which process is taking 100% CPU. Many times virus may modify known programs and would get listed as a valid executable.
Search for the process name and your observation on internet.
Search for known pattern(like accessing particular site, x number of tabs etc). If its repeatable then mostly its not a virus. Then follow cleaning steps like suggested.
28-05-2012, 01:13 PM #7
well i m not a pro at this but i don't think its a virus problem..
reasons..@ nikhilnayak said that his laptop is lagging it could be some kind of malfunction..
cuz what i don't get is how can he have problem with browser ...
i use a laptop too and its way old then yours plus 512 ram..and i m most of the time on net..
i too use Mozilla firefox,chrome and utorrent and i never had the lagging problem...like say i m downloading a game and plus i m searching on net, chatting, and other stuff but never had a problem...from the looks of it i guess u have a new laptop and it must have warranty and stuff..my advice..
1.get it to a service center or something and get it checked it could be a bigger problem,then u think..
or use a older version browser
28-05-2012, 06:59 PM #8Wise Old Owl
- Join Date
- Oct 2011
- Location
- Bangalore
- Posts
- 1,052
look in task manager which process is taking 100% of cpu.
28-05-2012, 07:08 PM #9
As others have suggested do a recce of the processes either from Task Manager or from "tasklist" in cmd. Just because you have NIS does not mean your system is impenetrable.
AMD Phenom II X6 1055T|MSI 880GMA-E45|MSI 7770|2x2 Corsair DDR3 1333MHz|CM Elite 310|Corsair CX400W|DELL ST2320L
Myself @ nbaztec.co.in
Build Your Rig! (XBlade) @ nbaztec.co.in - Build Your Rig!
My Inner Artist @ nbaztec.co.in - Designs
30-05-2012, 03:16 PM #10Right Off the Assembly Line
- Join Date
- May 2012
- Posts
- 5
I scanned with Malwarebytes, but found nothing at all!
30-05-2012, 07:49 PM #11Wise Old Owl
- Join Date
- Oct 2011
- Location
- Bangalore
- Posts
- 1,052
Nikhil,
try opera then you will love it with opera turbo on.
31-05-2012, 05:45 AM #12
@ OP - can you post a screenshot ( while the laptop is lagging ) of the task manager with process tab opened.
Who Dares Wins
Avenging Angel !
Phenom II 955BE↔Asus M5a97 R2.0↔Corsair 2x 4GB RAM↔HD6850↔Corsair GS600↔CM Hyper 212↔CM 430 Elite
My Blog : http://topgeartopspeed.wordpress.com/
BlackListed : Viewsonic, Gigabyte
31-05-2012, 10:05 AM #13
01-06-2012, 03:25 AM #14
^^ did not know about that command before .. will try it out .. TFS
Who Dares Wins
Avenging Angel !
01-06-2012, 06:58 AM #15
@OP See thread below..
[SOLVED] CPU usage above 56% even idle
urgent help required tracert information required from delhi mtnl user
By paroh in forum Software Q&AReplies: 6Last Post: 30-08-2009, 08:22 PM -
urgent help required abt N95 GPS
By mohitgiri in forum Mobiles and TabletsReplies: 4Last Post: 16-06-2007, 05:34 PM -
urgent help required..........
By kuldeep bhardwaj in forum QnA (read only)Replies: 1Last Post: 10-11-2006, 03:25 PM -
help required urgent.........
By sankhyag in forum TutorialsReplies: 1Last Post: 14-05-2006, 02:20 PM -
Urgent.. New MB required
By dilip281 in forum QnA (read only)Replies: 3Last Post: 24-10-2005, 11:39 PM
LinkBack URL
About LinkBacks
