Results 1 to 23 of 23
  1. #1
    In The Zone gurujee's Avatar
    Jul 2006
    Bhubaneshwar, Orissa, India, India
    Default Programme responds lately in XP
    Hi
    Recently I gave my 4 year old acer laptop to service center for servicing. after that i am facing a problem like after booting some programs taking a long time to open. If i opens firefox, sometimes it takes 5-10mins to open. during that many programs responds similarly. And after some minutes all of a sudden all programs opens one by one.
    I have windows xp, 1gb ram, 15gb free out of 40gb in C.
    what could be the problem ???
  2. #2
    Undead!!! Sujeet's Avatar
    Dec 2011
    India
    Default Re: Programme responds lately in XP
    Use Clceaner and Clean your System.
    The install a good Antivirus like Avast and do full system Scan for Virus.If that proves too time consuming then you can use MALWARE BYTES and do quick system scan and cleanup.
    HCL ME | Intel i3 310M | 320 GB | 2 GB DDR3 1333 MHz |
    HP ENVYM6 | Intel i5 3210M 2.5 GHz | 8GB DDR3 1600 Mhz | AMD Radeon 7670M | 1TB
    Samsung Galaxy Tab 2 |7.0 P31000
  3. #3
    Rusted... dashing.sujay's Avatar
    Nov 2009
    Bhopal
    Is it a problem with firefox only? Did you tried reinstalling?
    FAQ + answers for new members (Read before asking / messaging any moderator for any query)
    Drop Box: Get 500MB free
    Quote Originally Posted by axes2t2 View Post
    Before working on a master piece you have to first master the pieces.
    Sony Vaio CB35 Asus U32U ATH M20 Fiio E6
    Sony Vaio CB35 UnBoxing & Review
    How fast can you type?
  4. #4
    Computer Addict meetdilip's Avatar
    Apr 2009
    Remove unwanted programs from start up and check.
  5. #5
    Oct 2011
    Bangalore
    gurujee,
    I think you are using firefox 3.x upgrade to firefox 4 faster startup.which antivirus do you have?
  6. #6
    Game & anime Lover pkkumarcool's Avatar
    Sep 2010
    Florence
    i too hav same problem with firefox..
    On TDF after a loooo...nng time!
  7. #7
    Dec 2011
    India
    Quote Originally Posted by Minion View Post
    gurujee,
    Why Not Firefox 11??
    @OP move to Opera.!Its more Memory Efficient and will definitely help you since you 1GB of RAM only.
  8. #8
    Jul 2006
    Quote Originally Posted by dashing.sujay View Post
    yes i have reinstalled windows and programs after recieving laptop from service center.
    this problems occurs occasionally like 5 out of 10 times. and when it occurs, in my observation, all programs behave same way except opening my computer or control panel...
    gurujee,
    Quote Originally Posted by Sujeet View Post
    i have avg internet suite and firefox 11.
  9. #9
    Apr 2009
    Check free RAM before opening Firefox. Latest version of Firefox are a bit heavy on memory.
  10. #10
    In The Zone kiranbhat's Avatar
    Feb 2011
    sirsi
    remove avg its a useless and slowdown any pc.
    And control the startup programs
    use kav
    e5700+P5G41T-M LX+sapphireHD5670 DDR5 1gb+Transcend 3GB 1333Mh+wd 160gb
    HP ML115-G5
    DELL Inspiron mini 1018
    SAMSUNG Galaxy Y [COD Rom+kuro kernel+jellybean4.2 greaper]SonyEricsson k510i
    posted using tapatalk
  11. #11
    Dec 2011
    India
    Quote Originally Posted by gurujee View Post
    I would recommend you to install Avast AV in place of AVG.
    Much better Performer.
    If you want to go paid get Pro Version of Avast.
  12. #12
    Oct 2011
    Bangalore
    firefox 4 is much faster than firefox 11.and for antivirus go with ad-aware 10 very very light on resources.
  13. #13
    Jul 2006
    installed ans scanned cc cleaner. the problem hasnt arisen till now. lets see.
  14. #14
    Dec 2011
    India
    Its Fine Now then.
    Maybe it was a issue with registry and junk files.
  15. #15
    Jul 2006
    The problem still persists..
    Tomorrow i will buy Avast and see if it is for antivirus....
  16. #16
    Alpha Geek pranav0091's Avatar
    Jul 2011
    Wherever I am
    Open up task manager ans see if any program is consuming excessive memory or CPU.
    Check this when you are facing the issue of slow starts.
    HP Pavillion dv4 3016tx | i5 2.33GHz | ATI HD6750M 1GB | 4GB RAM | 500GB HDD
    Grado SR60i | Panasonic HJE120 | Soundmagic E10
    Lumia 920 | Nokia N70 | Sony Ericsson Xperia Ray
    Canon EOS 600D 18-55 Kit lens
  17. #17
    Fast 'N' Furious topgear's Avatar
    Jul 2006
    Geek's Heaven
    @ gurujee - scan your HDD for bad sectors - if it's a seagate drive use seatools dos version.
    Who Dares Wins
    Avenging Angel !
    Phenom II 955BEAsus M5a97 R2.0Corsair 2x 4GB RAMHD6850Corsair GS600CM Hyper 212CM 430 Elite
    My Blog : http://topgeartopspeed.wordpress.com/
    BlackListed : Viewsonic, Gigabyte
  18. #18
    Jun 2011
    Roorkee
    More than a malware isssue, I think its hardware related.
    As stated earlier check your hard disk for errors. Also run a memory test.
    Though am not ruling out any malware attack.
  19. #19
    ~Bulletproof Monk~ montsa007's Avatar
    Nov 2004
    Mumbai
    Disable startup programs that are unwanted using CCleaner
    Clean up temp files using CCleaner
    Do a registry cleanup
  20. #20
    Jul 2006
    Quote Originally Posted by topgear View Post
    ok..i have western digital.
    Quote Originally Posted by Vignesh B View Post
    i dont know , but is it not for ram or something...
    Quote Originally Posted by montsa007 View Post
    i have done that already , but not solved.
  21. #21
    Nov 2004
    Mumbai
    The best bet is to hard format the hard drive (takes lot of time compared to a quick format) and install a fresh copy of windows. (Consider using Darik's Boot N Nuke program)
    Avoid downloading windows updates (Most of them crap up the system as they are generic and not system specific updates)
    The hard format ensures all worms and rats are killed and taken care of, avoiding windows updates ensures you don't crap up the system.
    **Before formatting, just do a full scan with malware bytes software, let it run while you sip some coffee and watch it find the worms in your lappy (Again, full scan and not quick scan)**
    My lil cousin owns a Dell too (Some old model with very bad config, he starts the laptop 30 minutes before he wants to actually work coz it takes approx 30 minutes to boot and get ready for operating)
    Alternatively, you can install some other OS on the system which doesn't consume resources, like Ubuntu or some cloud OS.
    Am assuming you don't have multiple anti viruses installed in the system and you aren't using Norton Products (They choke the laptop to death)
  22. #22
    Jun 2011
    Roorkee
    Yes, use memtest86+
    If everything else fails, do what montsa007 has suggested.
  23. #23
    Jul 2006
    Geek's Heaven
    Use WD's Data Lifeguard Diagnostic for DOS - CD version
    Who Dares Wins
    Avenging Angel !
  1. Replies: 35
    Last Post: 07-09-2008, 02:42 PM
  2. Adobe CEO responds to Microsoft's Silverlight
    By nepcker in forum Technology News
    Last Post: 19-04-2007, 10:48 PM
  3. System responds terribly after dialing a connection
    By Vyasram in forum Software Q&A
    Last Post: 07-02-2007, 05:12 PM
  4. Replies: 5
    Last Post: 09-01-2007, 03:49 PM
  5. ps/2 mouse not responds after resuming standby
    By Aanand in forum Peripherals
    Last Post: 12-07-2006, 07:30 PM
