Old 27-09-2004, 11:09 AM   #1 (permalink)
Default XP trouble...help ASAP
ok, i was helping my roommate speed up his computer by removing programs frm the start up list in msconfig....but after we restarted, the computer was crawling....i undid all the changes....didnt help....i also tried system restore a few times but 2 no avail....what could the prob b? and remedies???? need replies asap!!!!
Nemesis is offline
Old 27-09-2004, 06:14 PM   #2 (permalink)
busyanuj's Avatar
Default Re: XP trouble...help ASAP
tell him to run chkdsk on his hard drive and then defragment it.
additionally, remove all unnecessary softwares from the taskbar.
it should help.
busyanuj is offline
Old 27-09-2004, 06:45 PM   #3 (permalink)
guys....ive already done defrag and chkdsk....and the problem started when i tried 2 remove the unnecessary stuff...and the problem is that his computer doesnt work even after restoring it and stuff...
Nemesis is offline
Old 28-09-2004, 12:35 AM   #4 (permalink)
Web Entrepreneur
ShekharPalash's Avatar
which antivirus was instaleed... NAV and McAfee creats problem in this kinda things...
try one thing...
http://sysinfo.org/startuplist.php
this website contains huge list of all start-up items...
if u remember what what things u disabled then we can tell ya some details...
if u can run in safe mode then also scan for spyware....
and if tht PC supports DEP then disable it... sometimes in certain conditions this also creates problem (i heard but not sure as i never had problem with DEP)
to do this
open boot.ini
and chage the /fast detect /NoExecute=OptIn
to only
/fastdetect
all the best...
Live Chat with Doctors 24x7 on my site http://healthcaremagic.com
ShekharPalash is offline
Old 28-09-2004, 12:48 AM   #5 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
Please post your HijackThis Logfile for better assesment of your problem.
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
Old 28-09-2004, 05:55 PM   #6 (permalink)
sorry 4 not replying earlier. but my roomie's computer seems 2 b working fine now. if there is a problem, i will post it up again...thanx 4 the help guys....
Nemesis is offline
Old 28-09-2004, 08:11 PM   #7 (permalink)
oh so was it a case of Xp faking a crash and a slowdown
its my gift....
its my curse....
who am i??
i`m spiderman....2!
godzi_85 is offline
- by chris
