Old 24-01-2012, 09:23 PM   #1 (permalink)
Level 96 Headbanger
DeSmOnD dAvId's Avatar
Default Weird Hard drive problem. EXEs disappeared.
Hi,
I am now facing a weird problem with my Seagate 1TB external hard drive. One day, i found that it was not getting detected. When it did, many of the EXEs have disappeared and random TMP files are scattered around various folders, bearing names like: trz3A7B.tmp, trz69F7.tmp, etc.
So, someone please tell me what in God's name is going on and how do I reclaim my data.
Thanks.
"Words meant to dwell in darkness shall never see the light of day.
Words can be broken, so can bones. Execute the mandate." :twisted:
Steam : DeathMetal
Garena : death_metal27
My Blog : The Pandemonium
(Latest Post : Where does music come from?)
Guitar gear : GB&A (acoustic), ESP LTD-M50 (New :twisted:), Roland MicroCube Amp.
DeSmOnD dAvId is offline   Reply With Quote
Old 25-01-2012, 10:03 AM   #2 (permalink)
Fullbring
Zangetsu's Avatar
Default Re: Weird Hard drive problem. EXEs disappeared.
^I think its affected by virus...scan it with good antivirus
Old 25-01-2012, 10:23 PM   #3 (permalink)
Neeraj J's Avatar
Post Re: Weird Hard drive problem. EXEs disappeared.
It is surely a virus issue. Scan your system with Stinger , Malwarebytes and Super Anti-Spyware. Also if you have any Anti-Virus & Anti-Spyware installed, probably exe files are infected with some virus,worms and your AV software might be deleting all exe files. So recommended is to complete scan your system by using tools mentioned above.
Neeraj J is offline   Reply With Quote
Old 27-01-2012, 11:18 AM   #4 (permalink)
Level 96 Headbanger
Scanned with Norton, found and got rid of all malware. Also, there was a worm called W32.Licum, which is said to infect exes. My hard drive was not with me when this case occured. So, I am guessing that the anti-virus at home detected all infected files and deleted them or changed them into temp files, I don't know. So, any idea how do I recover my data?
Steam : DeathMetal
Old 27-01-2012, 02:45 PM   #5 (permalink)
Would recommend you to uninstall Norton now. Download Free avast antivirus in a secured computer and move to a pendrive. But better to get a CD.
Boot into Safe mode, install the AV and do a complete scan. Dont install in normal usage. AV would also end up getting affected.
My Photography page on- Flickr
Follow me on - Twitter
Old 27-01-2012, 04:37 PM   #6 (permalink)
use any file recovery software like recuva. but remember it'll recovery pretty much everything including virus. do deep scan for better result but depending on hdd size it'll take time. several hours.
Old 27-01-2012, 05:46 PM   #7 (permalink)
Fullbring
Zangetsu's Avatar
^yes data recovery need huge amount of patience.
some good software are
Recuva,
miniTool Power Data Recovery,
EASES Data Recovery
Old 27-01-2012, 07:42 PM   #8 (permalink)
Level 96 Headbanger
Ok...will try Recuva. Will keep you posted.
Buddy, I got avast on my home machine. Didn't do a whole lotta good back then.
Steam : DeathMetal
Old 27-01-2012, 08:36 PM   #9 (permalink)
i got avast on my pc too. its virus scanning is on par or better than paid AVs but when it comes to detecting spywares, it fails a lot. you can try avira without the protection module so that Norton & Avira both are installed on your system without conflict.
Old 27-01-2012, 08:37 PM   #10 (permalink)
java is fun.
digitalage's Avatar
Seems like a virus but I would also suggest to contact Seagate support... check out this link.. https://services.seagate.com/ (found in google looks helpful)
digitalage is offline   Reply With Quote
Old 28-01-2012, 12:35 AM   #11 (permalink)
127.0.0.1
mitraark's Avatar
New Avast 6 has this Sandbox feature which keeps exes in Hidden folders and links them via Shortcuts
Intel i5 760 || Gigabyte H55 || Corsair 4GB 1333MHz Value || XFX HD5670 1GB
WD 2TB Green + Seagate 5900RPM 2 TB + Seagate Freeagent 1 TB x2
Corsair CX400 || Zebronics Bijli || Samsung P2350 23.5" || Altec Lansing VS2621
My Speedtest :D
mitraark is online now   Reply With Quote
- by chris
