Old 18-01-2012, 10:17 PM   #1 (permalink)
mortal kombat
quan chi's Avatar
Default kindly help to find the Driver for this
guys i have this ENTER - USB TO LAN but i am unable to find its driver.the cd which came with it reads blank or you can say corrupted.
can anyone please help.
quan chi is offline   Reply With Quote
Old 18-01-2012, 10:25 PM   #2 (permalink)
Boot through Ubuntu 11.10 Live CD. Open Terminal and type 'lsusb' without quotes. The chipset will get listed and search for the Windows driver.
Old 18-01-2012, 11:38 PM   #3 (permalink)
Super Moderator
asingh's Avatar
Default Re: kindly help to find the Driver for this
There has to be some model # printed on it.
asingh is offline   Reply With Quote
Old 19-01-2012, 12:10 AM   #4 (permalink)
mortal kombat
quan chi's Avatar
model no seems to be E100u.Btw windows also failed to search for its driver.
Old 19-01-2012, 12:31 AM   #5 (permalink)
Electronic.
Neuron's Avatar
http://www.4shared.com/file/AcoSemw8...LAN_WIN_7.html
I think that's it.
Link obtained from Support
I don't always make sense,but when I do,I don't.
Neuron is offline   Reply With Quote
Old 19-01-2012, 01:11 AM   #6 (permalink)
mortal kombat
quan chi's Avatar
^^Nope mate i tried that too but nothing happens.
Old 19-01-2012, 04:33 AM   #7 (permalink)
Fast 'N' Furious
topgear's Avatar
what OS you are on ?? The exact name of the device is JP1081 USB2.0 To Fast Ethernet Adapter ( JIAPENG Network Technology )
Use this app ( link below ) to get the drivers for it
http://www.drivermax.com/index.htm
ToPsPeEeD = FaSt BuT StEaDy
topgear is online now   Reply With Quote
Old 19-01-2012, 11:11 AM   #8 (permalink)
Stuck in Time...
Vyom's Avatar
Try searching in the best driver site, www.driverguide.com
You will have to register first, and need a little patience. But worth it.
Marty: Hey, Doc, we better back up. We don't have enough road to get up to 88.
Doc Brown: Roads? Where we're going, we don't need, "roads!" :)
──── On the Internet you can be Anything you want. It's Strange that, so many people choose to be Stupid! ────
Vyom is offline   Reply With Quote
Old 19-01-2012, 11:41 AM   #9 (permalink)
Super Moderator
asingh's Avatar
Why did you order such a novel device. There is so much Netgear, Asus, Belkin out there -- for this type of stuff.
Old 19-01-2012, 10:49 PM   #10 (permalink)
mortal kombat
quan chi's Avatar
Driver update - Use DriverMax to update all your Windows PC drivers
You have not been made mod for nothing!You are awesome!! it solved the problem.
anyways thanks to all the guys for replying.
Old 19-01-2012, 11:15 PM   #11 (permalink)
Stuck in Time...
Vyom's Avatar
Chalo bhai chalo... problem solved. topgear zindabad. Baki sab pani kam chai...
Glad that your problem is solved!
Old 19-01-2012, 11:34 PM   #12 (permalink)
THE CHOSEN ONE
Blue Ripazah's Avatar
can this be used to connect reliance usb modem to connect it to wifi router and distribute it further...
Intel i3 540|| Gigabyte H55M D2H || 2x2gb corsair value Ram|| :doublethumb: Saphire Hd 6670 :doublethumb:||:mrgreen: Samsung B2230 :mrgreen: || 500 GB Seagate || 80 Gb Seagate|| IBall 7299||Gsm Insipre 500 watt :banghead:||Creative A 300 with philips speakers ||Sony dvd rw|| Samsung Galaxy Ace 8-)||
Blue Ripazah is offline   Reply With Quote
Old 20-01-2012, 05:03 AM   #13 (permalink)
Fast 'N' Furious
topgear's Avatar
thanks and nice to know that you have got the correct drivers
Old 20-01-2012, 09:57 AM   #14 (permalink)
Electronic.
Neuron's Avatar
Wierd the driver provided by the manufacturer didn't work.Better not buy the products of such brands.
Old 20-01-2012, 01:15 PM   #15 (permalink)
Nope.
Old 20-01-2012, 01:39 PM   #16 (permalink)
THE CHOSEN ONE
Originally Posted by ico View Post
Nope.
is there any way to connect it to router without keeping the pc on ...
Old 20-01-2012, 01:46 PM   #17 (permalink)
You are talking of this, right?
You will not be able to share Reliance Netconnect Broadband+ using a simple router which has only ethernet and ADSL port.
You'll be needing a something like this: Hame HM432R
Supported modems: http://www.ekwireless.in/modems.html
Post source: http://www.thinkdigit.com/forum/1305542-post6144.html
You'd need a Wifi router which can accept a 3.5G USB Modem connected to it.
I hope I have understood your query fine.
What quan chi has is, a device which converts a USB port on the computer to an Ethernet (LAN) port.
Old 20-01-2012, 01:55 PM   #18 (permalink)
THE CHOSEN ONE
yes u got me right ....
so this means that i hv to buy another router that supports 3.5g ......
are they available in delhi....and how much do they cost ....
Old 21-01-2012, 01:21 AM   #19 (permalink)
Super Moderator
asingh's Avatar
Ico, embedded the link in the image he posted. That is my setup.
1. Check out the website for compatability to your 3G device. This is mandatory. You cannot just buy any router.
2. Contact Ekwireless and they can guide you how to buy it.
3. Else search the model you found matching to your 3G device on Ebay. Highly likey ekwireless will be the seller. I bought that black router from them
Best.
Old 21-01-2012, 04:41 AM   #20 (permalink)
Fast 'N' Furious
topgear's Avatar
It was the driver CD that did not work but trust me - sometime you just have to buy and use such things ! and after putting a little effort behind them they can really produce some good result
Old 21-01-2012, 01:32 PM   #21 (permalink)
THE CHOSEN ONE
Best.
how much did that cost...???
Old 21-01-2012, 03:00 PM   #22 (permalink)
Electronic.
Neuron's Avatar
I meant the driver provided on their site.It didn't work for him.Thanks for the info on drivermax by the way,quite handy.
Old 21-01-2012, 04:47 PM   #23 (permalink)
Super Moderator
asingh's Avatar
~3.8K or something.
Old 22-01-2012, 04:12 AM   #24 (permalink)
Fast 'N' Furious
topgear's Avatar
Ok .. got it.
you are welcome
