Old 17-01-2012, 05:06 AM   #1 (permalink)
Post "Digit Forum Offline" Installation Problem
I tried to extract the "Digit Forum Offline.exe" package (From December DVD). After extracting 26106 files (approx 12-13% of the compressed package) in the Lite\web folder it starts giving "cannot open output file" error. What may be the problem? Please try extracting that archive and tell me? There are no problems like CRC with the executable (compressed) file itself 'cause I copied the whole executable file (119MB file) to the hard disk without any problem, so the DVD is finely readable.
Windows XP SP2 32bit
HDD file system- FAT32
Uploaded with ImageShack.us
Digit Rox!!!
http://www.thinkdigit.com/forum/hardware-q/128731-ups-uninterruptible_power_supply-ups-battery-buying-advice-help-digitians.html
RajivKumar123456 is offline   Reply With Quote
Old 20-01-2012, 02:43 AM   #2 (permalink)
Post Re: "Digit Forum Offline" Installation Problem
No replies?!
Digit Rox!!!
Old 20-01-2012, 07:55 AM   #3 (permalink)
Electronic.
Neuron's Avatar
Default Re: "Digit Forum Offline" Installation Problem
Maybe the file is corrupt or there are many bad sectors on the drive.Try extracting it into a pendrive.
I don't always make sense,but when I do,I don't.
Neuron is offline   Reply With Quote
Old 20-01-2012, 08:51 AM   #4 (permalink)
I didnt have any trouble when extracting those files. Tried with other computers?
