Old 13-01-2012, 02:12 AM   #1 (permalink)
@ndroholic
pramudit's Avatar
Default Help.... kernel32.dll is gone missing
i was running WEI after my gpu OC and my computer crashed.....
now kernel32.dll is gone missing.....
Please some one help me.... Mine windows 7 version is 7601, SP1 installed, ultimate.... Please some one help me......
i opened windows again and found that kernel32 is not missing but OpenVxDHandle could not be located in the kernel32.dll .........
Intel Core 2 Quad Q8400 |Asus EAH4350 HD @ 720/480 (its summer time) | WD blue 500gb | Intel DG41RQ | 2gb DDR2 | HP DVD-RW | Creative 2.1 | SAMATRON 55V |
Samsung Galaxy Y
Garena id- pramudit
My coil Gun
pramudit is offline   Reply With Quote
Old 13-01-2012, 08:32 AM   #2 (permalink)
Computer Addict
meetdilip's Avatar
Default Re: Help....
sfc /scannow will replace missing Windows files.
meetdilip is offline   Reply With Quote
Old 13-01-2012, 09:19 AM   #3 (permalink)
The Warchief
Kola2842's Avatar
Connect you hd to different pc and backup. Then repair window files or format.
And don't be Panic
Sometimes this happen due to faulty driver files.
Kola2842 is offline   Reply With Quote
Old 13-01-2012, 10:36 AM   #4 (permalink)
Fullbring
Zangetsu's Avatar
@pramudit: boot through windows 7 DVD & use the Repair option to repair system files
Old 13-01-2012, 07:25 PM   #5 (permalink)
@ndroholic
pramudit's Avatar
Default Re: Help.... kernel32.dll is gone missing
done..... still the same problem...... however the computer gets started but i get this error in many applications.....
Samsung Galaxy Y
Garena id- pramudit
My coil Gun
