Old 07-09-2005, 12:10 PM   #1 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Default How to increase the size of desktop and explorer icons?
Guys!
I want to know how can I increase the size of Explorer icons and desktop icons in windows XP without using any s/w ?
I mean I want to increase the size of desktop and all explorer icons like Vista.
Is there ne way?
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 07-09-2005, 12:31 PM   #2 (permalink)
Location: a small room in a big house in a small street in a big city
To increase the size of desktop do a resolution change.
640x480 gives you a small desktop and 1024x768 or more gives you a big desktop (while in higher resolution if you cant read the text properly change the size of the fonts)
to view a large icon on your desktop right clik on your desktop >> go to properties >> go to appearance >> click advanced >> choose ICON in the ITEM drop down box >> enter the size required on the SIZE box next to it and click OK[/quote]
Hooray for games. (unfortunately i cant play any of \'em)
netarget is offline
Old 07-09-2005, 12:37 PM   #3 (permalink)
Microsoft MVP
thnx buddy!
I don't want to change the resolution.
But the Desktop properties trick worked.
Old 07-09-2005, 03:26 PM   #4 (permalink)
expertno.1's Avatar
@Visahl u could use even a better alternative i.e
Tweak UI
http://www.microsoft.com/ntworkstati.../NTTweakUI.asp
http://www.annoyances.org/exec/show/tweakui
expertno.1 is offline
Old 07-09-2005, 05:00 PM   #5 (permalink)
Distinguished Member
anandk's Avatar
try stardocks iconx. its cool.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
