Old 03-01-2012, 05:03 PM   #1 (permalink)
Firecracker to the moon
serpent16's Avatar
Default Help needed!!
I am really sorry if i posted this is the wrong thread as i couldn't find the right thread.
Ok right now i have a 500gb harddrive with windows xp.I want to install win 7 without loosing any data?How do i do it(Im going to ask someone to install it)
My Gaming Rig: AMD 965 BE||Gigabyte 7750 OC Edd-880 Mhz Review Coming soon
hd 7750 review
Steam:serpent161
serpent16 is offline   Reply With Quote
Old 03-01-2012, 06:14 PM   #2 (permalink)
mithun_mrg's Avatar
Default Re: Help needed!!
Just install it on a seperate free/empty partition other than C: i.e ur windows XP partition
it will be fine
Corei3-530@4.5,MSI P55-GD65,Gskill 4G,Coolit ALC,Tagan 500W,XFX 6850@1000/1200,MX 518,Razer Abyssus,Avermedia Pcie TV,Audigy,VS3251,Transcend MP330 8Gb, PL11, PMX 60,PSP 3000 , Galaxy 551,Nokia C1-02.
mithun_mrg is offline   Reply With Quote
Old 03-01-2012, 08:10 PM   #3 (permalink)
CA50's Avatar
If you don't want the XP, then install 7 over that XP partition, but if you want both, then you will have to create another partition (according to your need), or use an existing partition fro windows 7.
If you are too paranoid about your data, then copy your existing data from partition A (say) to partition B and install windows 7 on partition A
| A Bit IP35-Pro | E8400 | GTS250 | Gskill 2x2GB | 1.9 TB | CM EP+ 460W | 2x DVD-RW|
| Nokia 2700c |
CA50 is offline   Reply With Quote
Old 07-01-2012, 02:57 AM   #4 (permalink)
Undead!!!
Sujeet's Avatar
dude installing ur win 7 on separate wont help you get ur dual boot system in place bcoz as soon as win 7 will be installed that partition will be marked active and sytem will boot into win 7 directly without os selection menu(mostly occurs when installing win7 side by xp) so after installing win7 use EasyBCD to setup bootmenu for dual boot.
Sujeet is offline   Reply With Quote
Old 07-01-2012, 08:43 AM   #5 (permalink)
Installing on a separate partition is enough.
directly without os selection menu (mostly occurs when installing win7
side by xp
didnt happen with me. Installing Xp after Win 7 takes direct to Xp. But installing Win 7 after xp I could boot into Xp without any modification.
Old 07-01-2012, 10:19 AM   #6 (permalink)
Fullbring
Zangetsu's Avatar
@serpent16: I hope u have separate partitions for win XP & win 7 (in which u will install)
ex: Drive C: WIndows XP
Drive D: Windows 7
Drive E: Local
Old 08-01-2012, 09:22 AM   #7 (permalink)
Your Ad here
nisargshah95's Avatar
Thumbs up Re: Help needed!!
Newer operating system bootloaders have better compatibility with thier legacy counterparts.
Only the Windows 8 Developer Preview does not recognize XP. But it does recognize Vista/7/Server.
“The Web is like a dominatrix. Everywhere I turn, I see little buttons ordering me to Submit.”
ASUS P5KPL AM/PS | P4 @ 3.07GHz | Ubuntu 11.04 / Win Server 2k8 / XP SP3 | 1GB DDR2 | Samsung HD080HJ 80GB
nisargshah95 is offline   Reply With Quote
Old 08-01-2012, 10:05 AM   #8 (permalink)
serpent16's Avatar
Ill try keeping only win 7,The only problem is my parents they find win 7 really confusing as they say the font is small,they cant understand where the window goes when it minimizes ..And when i said them to update they say their friend is still using windows 95 why do i want win 7
hd 7750 review
Steam:serpent161
Old 13-01-2012, 11:15 PM   #9 (permalink)
Your Ad here
Smile Re: Help needed!!
Happens. There's a need to teach them.
Old 14-01-2012, 12:05 AM   #10 (permalink)
Computer Addict
meetdilip's Avatar
It is quite easy. Make a 40 or 45 GB partition on your present hard disk, remember its name and install W7 to it. Once installed, you will be able to choose between XP and 7. The problem occurs only if you install XP after 7.
meetdilip is offline   Reply With Quote
Old 16-01-2012, 12:28 AM   #11 (permalink)
Undead!!!
Sujeet's Avatar
Looks like i messed up with my words in referring to the bootloader prob of xp and win7/8.
Thanks guys for pointing it out ...problem occurs only if xp is installed after win 7(can be fixed with easyBCD anyway)!!TESTED & Assured!
Hollywood Undead
I want to teach you to live the truth, to reveal the light within your own soul-Swami Vivekanand.
Greatest Troll of Millennium.Here
Old 16-01-2012, 02:36 AM   #12 (permalink)
Computer Addict
meetdilip's Avatar
Nice that it is working
Old 16-01-2012, 09:16 AM   #13 (permalink)
serpent16's Avatar
Yea,So so i am thinking of keeping only Win 7.So i can install it in C drive(Where XP is),And be safe of not loosing my data(In d,e,f)??
hd 7750 review
Steam:serpent161
Old 16-01-2012, 10:58 AM   #14 (permalink)
Computer Addict
meetdilip's Avatar
Yes, but after formatting it first.
