can anybody tell me the alternate option for fixing avi index which vlc player shows for a broken avi file....and it takes too much time for fixing it..
sometimes when i encounter these errors i simply convert them to some other format using Format Factory (or similar converter). most of the time it gets fixed.
yes. most of the time. with format factory either you get a fully working file or the conversion will fail and there won't be any output. i do this for media files recovered from friend's formatted pendrive
nope..three possibilities are there
A.fully working file
B.failed conversion
C.Partial working file (will be converted to a particular time line)
