Old 23-12-2011, 11:26 AM   #1 (permalink)
Red face there is same folder with .vbs extension in every folder
in my computer there is folder with same name as the parent folder with .vbs exstension.
i have scanned the whole computer with AVG internet security 2011. but nothing found during the scan. my system also become very slow.
please help me how to solve this problem.
thanks in advance.
Ishan Arora
ishan_arora is offline   Reply With Quote
Old 23-12-2011, 12:26 PM   #2 (permalink)
Default Re: there is same folder with .vbs extension in every folder
i remember AVG creating some log files at the root of each & every drive. .vbs may point to some script virus. install avira without protection module over avg, update it & scan whole system. slowdown can also be caused by avg. have personally experienced it long ago.
Old 23-12-2011, 12:37 PM   #3 (permalink)
Rubik's Uncle!!
Charan's Avatar
vbs extension is usually the extension for executable VB Scripts, just check if its a script file by opening it in notepad.. DONT DOUBLE CLICK AND EXECUTE IT OPEN IT IN NOTEPAD AND CHECK..
Charan is offline   Reply With Quote
Old 23-12-2011, 12:42 PM   #4 (permalink)
Democracy is a myth
rhitwick's Avatar
Seems a worm...
Scan your computer by Avira.
"My opinions may have changed, but not the fact that I am right."
"I'm never wrong. Once I thought I was wrong, but I was wrong"
rhitwick is offline   Reply With Quote
Old 23-12-2011, 01:00 PM   #5 (permalink)
You are definitely infected. Do a scan with online antivirus HouseCall - Free Online Virus Scan - Trend Micro USA
Old 27-12-2011, 01:59 AM   #6 (permalink)
CA50's Avatar
Get avast and update it, next run a through boot time scan.
Also get spybot search and destroy and scan you system for any kind of malwares
| A Bit IP35-Pro | E8400 | GTS250 | Gskill 2x2GB | 1.9 TB | CM EP+ 460W | 2x DVD-RW|
| Nokia 2700c |
CA50 is offline   Reply With Quote
