22-12-2011, 04:21 PM
Internet speed going down bcoz of Torrents.
In my office we have a 2mbps broadband Internet line. The Internet comes to our system via a Router. I'm the only person who requires Internet at my place. I'm a Graphic Designer so I've to upload lot of files over net, so I thought I'd use Internet (Downloading) discreetly. So I installed a torrent client on my PC. But the problem is whenever I turn on the torrent the whole network PCs Internet goes slow. I donno what is happening. The max speed I can get out of my internet is 190kBps. But if I turn on torrent client even with 30kBps the whole networks speed goes so down that even a webpage does not open. Plz help me.
I'm not much of a network person plz use easy language for me to understand.
22-12-2011, 04:36 PM
Mmmph!!!
Re: Internet speed going down bcoz of Torrents.
check with your network admin.
ask him if torrent downloads are being throttled.
also, download some brush back off piratebay, just to appear legit, and show him the speeds.
Mmmphh-mphhhh-mmphh mhh!!!
Steam : doomgiver
22-12-2011, 04:42 PM
^^ I do not think that torrents are really throttled. Problem is at the instant I start BitTorrent, the whole Internet on our network goes slow. Even if speeds I'm getting on torrent are extremely low.
22-12-2011, 05:35 PM
check amount of bandwidth used by torrent client by resource monitor if you are using windows
22-12-2011, 08:58 PM
^^ I'll try that out and post the results tomorrow.
22-12-2011, 10:44 PM
use netbalancer to prioritize which app should get best speeds..
| Athlon II X4 635 @ 2.9Ghz | | Gigabyte GA-MA785GMT-US2H | | Kingston 2x2 Gb 1333Mhz DDR3 | | WDC 500Gb Green | | Palit GTS 250 512mb | | Tagan 500W | | Samsung B2030 | | Lg DVD Writer |
22-12-2011, 10:46 PM
Super Moderator
Then the throughput of your line actually is not 2 Mbps. Even slow torrents are throttling the whole LAN, means your speed is substantially lower than 2 Mbps. Seems like you are on some 512kbps connection.
23-12-2011, 01:54 AM
yes guys mine too getting slow while downloading torrent
512kbps bsnl ul
23-12-2011, 08:06 AM
i have a single pc and same problem here. i have bsnl 2mbps, websites don't open or they open very slow even if i set download speed in torrents to less than 100KBps, my original download speed is 200KBps. so even if torrents use less bandwidth the remaining 100KBps bandwidth is not distributed to other applications.
23-12-2011, 08:58 AM
Still A Student!!!
TOrrent clients actually use up a lot of bandwidth while downloading.. You can limit it by going to the preference option and make the maximum download rate to 30kbps or anything that may speed up your browsing speed.. These goes for windows only. Dunno about linux
23-12-2011, 11:53 AM
Hanging, since 2004..
Limit the download and upload speed through the utorrent client, also encrypt the traffic from the options so ISP cant identify what type of traffic it is , hence wont be able to throttle.
Windows 8 ? :lol:
I have a better OS installed, people call it Windows7 8-)
23-12-2011, 04:28 PM
I'd've put up the results network monitoring but we have problems in LAN today so I'll put it up tomorrow. The problem starts as soon as I turn ON the torrent client, the speed I'm getting doesn't really matter be it 30 or 100. And I'm sure that nor ISP nor the Admin is throttling my speed. And even if they're doing it, that shouldn't really affect the whole networks internet speed.
23-12-2011, 09:43 PM
King of my own Castle
Also sometimes though we could be downloading @ 10 kbps on torrent but the upload speed could be unlimited effectively chocking your bandwidth...Set the upload speed to predetermined cap.
23-12-2011, 10:09 PM
In the Zone
Reduce the upload Speed and the 'number of connections per torrent' to a lower amount. You can find the options for these in the preferences menu if you are using utorrent.
Acer Aspire 4930G laptop- Core 2 Duo T5800 3GB ram, 320GB+LG XG1(2TB),nVIDIA 9300GS 256MB,FingerPrint Scanner,HDMI, 802.11a/b/g/Draft N Wifi Sony Ericsson Xperia Arc S (Gloss Black)
25-12-2011, 12:00 AM
Have you tried changing the torrent client ?
Quality Hosting Solutions
SunTex Hosting
www.SunTexHosting.com
