Old 25-11-2011, 02:34 AM   #1 (permalink)
crazylamhe's Avatar
Exclamation .BIN extensions
I have many videos in .BIN format. However, Windows Media, VLC, KMPlayer all show error messages. I googled it, but most of the results showed that VLC should play it. I have even used third-party software to convert the files, but they refused . Plz. Help
crazylamhe is offline   Reply With Quote
Old 25-11-2011, 11:00 AM   #2 (permalink)
Fullbring
Zangetsu's Avatar
Default Re: .BIN extensions
^^try potplayer
VLC should play it...
also try UltraISO for bin files
Old 25-11-2011, 11:53 AM   #3 (permalink)
Stuck in Time...
Vyom's Avatar
What are the size of those .BIN files? Are you sure, they are videos?
Their are .BIN files on a video DVD's too, but most of them are just to support the playback on DVD players. The actual video files are those .VOB files present on the DVD.
Marty: Hey, Doc, we better back up. We don't have enough road to get up to 88.
Doc Brown: Roads? Where we're going, we don't need, "roads!" :)
──── On the Internet you can be Anything you want. It's Strange that, so many people choose to be Stupid! ────
Vyom is offline   Reply With Quote
Old 25-11-2011, 12:57 PM   #4 (permalink)
Fullbring
Zangetsu's Avatar
let me add this..
BIN is binary format extension used in many file types
such as BIOS file (.bin)
Video File (.bin)
Image File (.bin)
Ninento DS system files (.bin)
OS system files (.bin)
etc etc
Old 25-11-2011, 11:40 PM   #5 (permalink)
crazylamhe's Avatar
They are a series of videos on Ethical Hacking, which was shared on my hostel LAN. Their sizes vary according to the time. For ex., a 1 hr. lecture is approx 72 MB long. The worst thing is that VLC is unable to play it ! Will be trying the Pot Player soon . . Thanks for your support guys !
Old 25-11-2011, 11:48 PM   #6 (permalink)
Stuck in Time...
Vyom's Avatar
In that case, you can try to convert those files into appropriate format, through converters like, Any Video Convertor. (Link: Editors and Convertors Downloads - FileHippo.com)
And then check if it plays.
Old 26-11-2011, 02:07 AM   #7 (permalink)
VIP
RazorbladeXtreme's Avatar
Maybe you've been given the image of the discs the videos were recorded on. Try opening one with WinRAR, also try Daemon Tools for mounting.
Twitter: twitter.com/SharmaTushar
Facebook: facebook.com/tushar.sharma
RazorbladeXtreme is offline   Reply With Quote
Old 26-11-2011, 07:32 AM   #8 (permalink)
Fast 'N' Furious
topgear's Avatar
Or the video files may be corrupted - that's why no player is able to play it.
ToPsPeEeD = FaSt BuT StEaDy
topgear is online now   Reply With Quote
Old 26-11-2011, 01:01 PM   #9 (permalink)
crazylamhe's Avatar
Thumbs down Re: .BIN extensions
Already Used a converter but The videos refused....
Worked my hands on them also(tried to mount with the daemon tolls).. didn't help !
Hmmm... I also think so..
No suitable decoder module:
VLC does not support the audio or video format "undf". Unfortunately there is no way for you to fix this.
This is the message shown by VLC when I ask it to play !!
Old 26-11-2011, 01:55 PM   #10 (permalink)
Project Halcyon V2.0
tkin's Avatar
Try SMPlayer(front end of famous mplayer), it plays files vlc can't.
On a side note, download and install this: MediaInfo
Find out the video/audio codec.
Project Halcyon v2.0:
[i7 2600k|Asus Z68 VPro|Vengeance 2x4GB|MSI GTX580 Lightning]
[TX 750v2|Seagate 500GB+WD Cav Black 1TB|CM HAF 912 Adv]
[Logitech G110|G500|Adata/750GB+WD/500GB USB 3.0]
[APC 1100VA|XBox 360 Controller|Noctua U12PSE2]
[Siberia Soundcard(Xear 3D)|Koss Portapro|FiiO E6]
[Audio Technica M35|PL30/EOL'ed]
tkin is online now   Reply With Quote
Old 27-11-2011, 12:08 AM   #11 (permalink)
VIP
Try ISObuster
How to rip the video from (S)VCD CDs or BIN/CUE images
