Old 07-11-2011, 05:08 PM   #1 (permalink)
Default Imporoving the sound quality how?
Hi Guys,
When I listen to music through CD with windows media player version. 11.0.5721.5268, the sound is not good enough though I changed the settings to maximum level. Is there any way to increase the sound output to a high level?
kumarn_2004 is offline   Reply With Quote
Old 07-11-2011, 05:27 PM   #2 (permalink)
Fullbring
Zangetsu's Avatar
Default Re: Imporoving the sound quality how?
@kumarn_2004: how much is the bitrate of the songs u r playing?
try AIMP player
Old 07-11-2011, 05:48 PM   #3 (permalink)
Democracy is a myth
rhitwick's Avatar
Try KMplayer. It allows you to change a lot of settings related to audio o/p.
Try it.
"My opinions may have changed, but not the fact that I am right."
"I'm never wrong. Once I thought I was wrong, but I was wrong"
rhitwick is offline   Reply With Quote
Old 07-11-2011, 07:06 PM   #4 (permalink)
Computer Addict
meetdilip's Avatar
Did you made any changes to equalizer ? Try default settings and check. The sound quality depends a great deal on your speaker quality, try using a better speaker and check. You can also try VLC player or Winamp and see if there is any difference.
meetdilip is offline   Reply With Quote
Old 07-11-2011, 07:11 PM   #5 (permalink)
sriharsha_madineni's Avatar
Originally Posted by kumarn_2004 View Post
Hi Guys,
Sound output at high levels get distorted.
What do you mean by sound not good enough. Sound Quality or Volume??
[Intel E8400]+[Intel DP35DP]+[4GB DDR2]+[GTX 560Ti]+[Corsair VX450]+[Altec Lansing VS3251R 5.1]+[DELL S2409W]+[Logitech MX-518] [iPod Touch 32GB] [iPhone 4 16GB] [Galaxy S II] [Sony Vaio EB26]
sriharsha_madineni is online now   Reply With Quote
Old 07-11-2011, 07:53 PM   #6 (permalink)
Hi Guys,
If I play CDs of vedio and audio,the sound also not good enough.Some CDs support only windows media player not other players.
Old 07-11-2011, 08:20 PM   #7 (permalink)
In that case you need to install codecs for playing that particular format or try players like kmplayer, vlc or klite codec pack.
Old 07-11-2011, 10:12 PM   #8 (permalink)
Stuck in Time...
Vyom's Avatar
@kumarn_2004: THIS...
Marty: Hey, Doc, we better back up. We don't have enough road to get up to 88.
Doc Brown: Roads? Where we're going, we don't need, "roads!" :)
──── On the Internet you can be Anything you want. It's Strange that, so many people choose to be Stupid! ────
Vyom is offline   Reply With Quote
Old 07-11-2011, 10:31 PM   #9 (permalink)
BMG ftw!!
d6bmg's Avatar
Use any codec pack (best one, k-lite codec pack) with WMP to get the best result.
d6bmg is offline   Reply With Quote
Old 08-11-2011, 04:36 AM   #10 (permalink)
Fast 'N' Furious
topgear's Avatar
get KMPlayer - in KMplayer right click anywhere -from the pop up menu select Audio > Normalizer ( put a tick mark beside this to enable the Normalizer filter ) - you will get a lot better audio quality - if you want to improve it furthere you mat play with other audio settings/filters available in KMPlayer
ToPsPeEeD = FaSt BuT StEaDy
topgear is online now   Reply With Quote
Old 08-11-2011, 06:22 AM   #11 (permalink)
Computer Addict
meetdilip's Avatar
Try VLC player, it plays almost anything. I forgot when I last used Windows Media Player.
Old 08-11-2011, 07:01 AM   #12 (permalink)
SuperMASSiVE
stonecaper's Avatar
Forget everything Use Winamp Lite+Enhancer 0.17 plugin/Foobar2K with Noise sharpener Plugin
u will be surprised With the sound quality
Steve Jobs (February 24, 1955 – October 5, 2011) & Jagjit Singh (8 February 1941 – 10 October 2011)
RIP
stonecaper is offline   Reply With Quote
